Layer positioning via dialog
Layer positioning via dialog Mauro Condarelli 21 Jun 17:33
  Layer positioning via dialog VytautasP 21 Jun 23:39
Layer positioning via dialog Mauro Condarelli 22 Jun 10:36
  Layer positioning via dialog saulgoode@brickfilms.com 22 Jun 12:50
Layer positioning via dialog Mauro Condarelli 22 Jun 15:04
Mauro Condarelli
2006-06-21 17:33:59 UTC (over 19 years ago)
I have a set of layers I need to position in the image at precise (to the pixel) positions. I *know* I can move them using the move tool, but it is a real pain. I Have been searching for some dialog where I can say exactly where in the canvas (much bigger than the layers) I want to have the (e.g.) top left corner of the layer. I have seen the Layer->Transform->Offset menu, but this gives an offset for the content into the leayer, while I need to set the offset of the layer into the image. I know It must be available somewhere, but I can't find it! :(
Thanks for Your help! Mauro
VytautasP
2006-06-21 23:39:33 UTC (over 19 years ago)
You can move with move tool with keyboard for higher precision. Choose layer with Page Up/Down key, press M and you can move chosen layer with arrows keys by 1 pixel, or by 10 pixels with arrows keys, while holding Shift button.
Mauro Condarelli
2006-06-22 10:36:50 UTC (over 19 years ago)
Date: Thu, 22 Jun 2006 00:39:33 +0300 From: VytautasP
To: Mauro Condarelli
CC: gimp-user@lists.XCF.Berkeley.EDU Subject: Re: [Gimp-user] Layer positioning via dialog ==========================
pain.
Mauro
Shift button.
Thanks.
It helps.
I would be much happier if I could have some kind of feedback. E.g.: a box showing the position of the layer into the canvas.
I have to position a huge (>100) number of (partially overlapping) layers on a regular grid. The Layers come from a single huge image that has been cut and I want to reconstruct. Relying on the image itself for positioning leads to errord that sum up :( I know the single layers were taken 1553x1038 pixel apart (horizontalxvertical), so, having the offset, it would be trivial to position them precisely.
Any further idea??
TiA Mauro
2006-06-22 12:50:10 UTC (over 19 years ago)
Quoting Mauro Condarelli :
Any further idea??
The following Script-fu will allow you to enter numerical offsets into a dialog box. Script-fu is unable to provide a visual preview of the result but perhaps this will suit your needs (you can UNDO the operation if the result is unsatisfactory).
Save the text below as a file named "layer-offset.scm" in your scripts directory. The command will appear as "Script-Fu->Transform->Layer Offset".
(define (script-fu-layer-offset image layer offset-x offset-y resize?) (gimp-image-undo-group-start image) (gimp-layer-set-offsets layer offset-x offset-y) (if (= resize? TRUE)
(gimp-image-resize-to-layers image) )
(gimp-displays-flush)
(gimp-image-undo-group-end image) )
(script-fu-register "script-fu-layer-offset" "/Script-Fu/Transform/Layer offset" "Offset the layer relative to the image" "Saul Goode"
"Saul Goode"
"6/22/2006"
SF-IMAGE "Image" 0
SF-DRAWABLE "Drawable" 0
SF-ADJUSTMENT "Offset X" '( 1553 0 5000 1 10 0 1 ) SF-ADJUSTMENT "Offset Y" '( 1038 0 5000 1 10 0 1 ) SF-TOGGLE "Resize image?" TRUE
Mauro Condarelli
2006-06-22 15:04:34 UTC (over 19 years ago)
Date: Thu, 22 Jun 2006 03:50:10 -0700 From: saulgoode@brickfilms.com
To: gimp-user@lists.XCF.Berkeley.EDU Subject: Re: [Gimp-user] Layer positioning via dialog ==========================
Any further idea??
THANKS!!!
Nice :)
.. since You seem so knowledgeable...
Is there a simple way to to make a dialog that does not change the values, but updates them when I move the layer?
Is this possible at all? I mean: is it possible for a dialog to react to changes made to the image? This seems to imply some kind of notification/callback mechanism that I don't know if it's implemented at all.
I *will* try to get info about the available functions in the docs, but a pointer would be welcome. :)
TiA Mauro
