Am I stupid!? Changing color does not work
Am I stupid!? Changing color does not work Norbert Preining 15 Jun 02:13
  Am I stupid!? Changing color does not work Carol Spears 15 Jun 02:48
   Am I stupid!? Changing color does not work saulgoode@brickfilms.com 15 Jun 04:28
   Am I stupid!? Changing color does not work Norbert Preining 18 Jun 08:55
Norbert Preining
2006-06-15 02:13:34 UTC (over 19 years ago)
Hi all!
I have an image and I want to change all colors into a different one. So what did I do:
* Select region by color
* switch to pencil tool
opacity 100
mode normal
circle big
color the new I want
and then I thought I can draw and the colors would be exchanged.
Well, instead of a nice blue I get a smeary grey, strange. Looks like instead of *replacing* the values of the pixels some combination of the pixel values is done.
I thought with opacity 100 this will not happen, but I seem to be wrong. Any idea/help???
Best wishes
Norbert
------------------------------------------------------------------------------- Dr. Norbert Preining Università di Siena gpg DSA: 0x09C5B094 fp: 14DF 2E6C 0307 BE6D AD76 A9C0 D2BF 4AA3 09C5 B094 ------------------------------------------------------------------------------- ABOYNE (vb.)
To beat an expert at a game of skill by playing so appallingly that none of his clever tactics or strategies are of any use to him. --- Douglas Adams, The Meaning of Liff
Carol Spears
2006-06-15 02:48:55 UTC (over 19 years ago)
On Thu, Jun 15, 2006 at 02:13:34AM +0200, Norbert Preining wrote:
Hi all!
opacity 100
mode normal
circle big
i think you are probably painting an indexed image.
change the mode to rgb using Image/Mode/RGB
you are not stupid. your image is.
2006-06-15 04:28:05 UTC (over 19 years ago)
If you are indeed editing an Indexed image, you may wish to leave it in Indexed Mode and open the "Dialogs->Color Map" window. This will allow you to individually change each of the colors in the image. This will be tedious if you have more than a couple dozen colors but if you have only a few (for example, a cartoon graphic), this is a quick and easy way to change the colors.
Quoting Carol Spears :
Hi all!
opacity 100
mode normal
circle big
Norbert Preining
2006-06-18 08:55:41 UTC (over 19 years ago)
Thanks a lot, I will check this ASAP. Didn't cross my mind.
Best wishes
Norbert
------------------------------------------------------------------------------- Dr. Norbert Preining Università di Siena gpg DSA: 0x09C5B094 fp: 14DF 2E6C 0307 BE6D AD76 A9C0 D2BF 4AA3 09C5 B094 ------------------------------------------------------------------------------- `Time is an illusion. Lunchtime doubly so.' you should send that in to the
"Reader's Digest". They've got a page for people like you.' --- Ford convincing Arthur to drink three pints in ten --- minutes at lunchtime. --- Douglas Adams, The Hitchhikers Guide to the Galaxy
