how to remove color spot
3 of 4 messages available
how to remove color spot Joey Morris 31 May 03:15
  how to remove color spot Roberto Winter 01 Jun 07:15
20060602023322.544.qmail@we... 07 Oct 20:17
  how to remove color spot Roberto Winter 02 Jun 05:40
Joey Morris
2006-05-31 03:15:01 UTC (almost 19 years ago)
I have a photo with a hexagonal green spot that I'd like to remove. I imagine the spot was caused by the position of the sun in the photo:
http://community.webshots.com/photo/550815856/2057089240091450488rWqiNx
Any suggestions on how to remove it? I tried using the Hue-Saturation tool to desaturate various colors in the area, and it helped some but still left a noticeable spot. I've seen lots of suggestions to use the Clone tool, but I don't think that will work because I want to keep the limb detail behind the spot.
Thanks.
Joey
___
Roberto Winter
2006-06-01 07:15:30 UTC (almost 19 years ago)
I do:
http://www.rhwinter.com/gimp/removeFlare/ (hope you don't mind me using your image. I wanted to link back to your page or something, do you have one?...)
roberto
Thanks.
Joey
___
Roberto Winter
2006-06-02 05:40:09 UTC (almost 19 years ago)
(I'm sending this to the list as well)
On 6/1/06, Joey Morris wrote:
Excellent! Thank you for your help Roberto.
no problem!
And thanks
for giving me the right term -- lens flare.
oh, I thought you had mentioned it on your original message. maybe I should introduce that somewhere on the tutorial. maybe add a link
Nah, there's no page to link back to. Also, it's no
problem for you to use the image.
thanks a lot!!!
roberto
Joey
--- Roberto Winter wrote:
I do:
roberto
I'd
the
the
in
use
Thanks.
Joey
___
