what causes platform color differences
what causes platform color differences Never you mind 23 May 01:27
  what causes platform color differences Tim Jedlicka 25 May 06:24
Never you mind
2006-05-23 01:27:18 UTC (almost 19 years ago)
I'm having trouble with a background image and
The image is very pale. It displays nicely on my Mac and my FreeBSD box but on the Windows machine the reds and yellows are completely washed out.
What causes such a difference in display and how can I minimise that effect?
malcolm
Tim Jedlicka
2006-05-25 06:24:22 UTC (almost 19 years ago)
They both look pale on my Linux driven monitor. It sounds like you are hitting a gamma issue. I -think- the Mac uses a gamma of 1.8 where as Linux and Windows is usually set to a gamma of 2.2. You might check out this site and see if it helps: http://www.normankoren.com/makingfineprints1A.html#gammachart
malcolm
