Mosaic of Images
Mosaic of Images Ezequias Rodrigues da Rocha 17 May 13:59
  Mosaic of Images Vytautas P. 17 May 17:27
   Mosaic of Images Paul Bloch 17 May 18:18
  Mosaic of Images Michael Schumacher 17 May 18:43
Mosaic of Images Vytautas P. 17 May 18:33
2006-05-17 13:59:28 UTC (almost 19 years ago)
Mosaic of Images
HI list,
Is possible to make a new image based in a group of images without using copy and paste ?
I have many images and would like to put all togeather in one single image. Is there any function that do it ?
Regards...
Vytautas P.
2006-05-17 17:27:53 UTC (almost 19 years ago)
Mosaic of Images
2006.05.17 14:59, Ezequias Rodrigues da Rocha paraš?:
HI list,
No
Paul Bloch
2006-05-17 18:18:56 UTC (almost 19 years ago)
Mosaic of Images
Actually, I think there is a way to make a mosaic although I've never tried it. Funny that you asked this question because I was looking it up yesterday. There's an image mosaic plug-in for Gimp. Check out: http://www.kirchgessner.net/photo-mosaic.html . Let me know if you're successful at all.
Cheers,
Paul
HI list,
No
Vytautas P.
2006-05-17 18:33:13 UTC (almost 19 years ago)
Mosaic of Images
This message should be sent for mailing list, not personally me. Check when sending, Paul:)
REDIRECTING...
Cheers,
Paul
HI list,
No
2006-05-17 18:43:33 UTC (almost 19 years ago)
Mosaic of Images
Von: Ezequias Rodrigues da Rocha
Load the images as layers and arrange them on a background layer, for example. The poster plug-in might help: http://www.macgeisler.de/gimp/the_gimp.html#poster
There are other possibilities, depending on the definition of "group". Maybe one of the contact sheet scripts (see http://registry.gimp.org) fits your requirements, or maybe you'll be better off with the montage command which is available from ImageMagick or GraphicsMagick.
