Solved Re: How to draw a line? :(
10 of 10 messages available
Line tool with Arrows andy.x.johnson@Cummins.com 12 May 20:18
  How to draw a line? :( Simon Roberts 12 May 21:02
   How to draw a line? :( Marco Wessel 12 May 21:06
    How to draw a line? :( Simon Roberts 12 May 22:03
     How to draw a line? :( Albert 12 May 22:21
      How to draw a line? :( Gracia M. Littauer 13 May 00:47
       The Lighting Effects plug-in MillTek 13 May 01:54
Line tool with Arrows Asif Lodhi 12 May 22:54
How to draw a line? :( Bob Long 13 May 01:05
  Solved Re: How to draw a line? :( Simon Roberts 13 May 02:36
2006-05-12 20:18:44 UTC (almost 19 years ago)
Is there anyway to draw a line in gimp and put arrows at the end of the line. Photoshop's line tool can apparently do this with ease...
Simon Roberts
2006-05-12 21:02:49 UTC (almost 19 years ago)
I'm feeling particularly useless today, I'm pretty much a total beginner with GIMP, but I can't believe this is as hard as I seem to be making it.
I want to draw a straight line. I'm using Gimp 2.2.4
I try the paintbrush, I have a color selected, and I can draw a squiggly line. The help says that holding shift down will make all these tools constrained to straight lines, but mine doensn't draw anything. It looks like it's trying to do measuement or something.
I try the path tool (which I can't claim to understand) and then try to "stroke" the path. I get polygons while I'm messing about, I can also get curves, but I don't seem to be able to get an actual line that stays on the page.
What I _want_ is a straight line, constrained to horizontal or vertical, drawn with the caligraphic brush (so it has a chiselled end) and using the "fade out" option, so it disappears smoothly over a distance.
Anyone want to tell me what's so obvious that I've missed it?
Thanks in advance, Simon
___
Marco Wessel
2006-05-12 21:06:05 UTC (almost 19 years ago)
Did you read the actual straight line tutorial? It's here:
http://www.gimp.org/tutorials/Straight_Line/
It details exactly what to do, step-by-step.
Marco
making it.
___
Simon Roberts
2006-05-12 22:03:09 UTC (almost 19 years ago)
Gach, hit reply, instead of reply to all.
Nutshell version: no, I'd not seen this, yes, so far as I can make out, I'm doing what the tutorial says, but no, I don't get any line.
I get two crosshairs and a line joining the two as I move the mouse while holding shift (I can constrain the line to certain angles with control too) but when I release shift, the whole thing goes away.
Foreground and background are both set to contrasting colors compared to the current image color.
Any thoughts?
TIA Simon
Marco
making it.
also
end)
___
Albert
2006-05-12 22:21:42 UTC (almost 19 years ago)
Did you press the left mouse button before releasing the shift-key, as the tutorial specifies?
Any thoughts?
TIA Simon
Asif Lodhi
2006-05-12 22:54:00 UTC (almost 19 years ago)
Hi Andy,
On 5/13/06, gimp-user-request@lists.xcf.berkeley.edu wrote:
Message: 5
Date: Fri, 12 May 2006 13:18:44 -0500 From: andy.x.johnson@Cummins.com
1) Select Brush tool with the desired brush size. 2) Click with the brush tool somewhere on the canvas. That will, for example
make the start of the line. 3) With SHIFT pressed, click with the brush tool somewhere else where you want
the arrow line to end. This will draw a straight line with your brush type. Release
the SHIFT key then.
4) Now draw the arrow-head (two tiny lines jutting out from one end of the line) the
same way. You can draw a filled arrow-head the same way - just draw one more
tiny line joining the two other tiny lines going angularly outwards from the end of
the main line and then FILL it with the bucket tool with the color you used to draw
the arrow.
Now, for example, if you do it on a flat-color background then you can
easily select it and convert it to path so that you can shape it to your liking.
OR, save it as a brush.
Hope that sounds easy.
Gracia M. Littauer
2006-05-13 00:47:34 UTC (almost 19 years ago)
aside from the fact that I feel like I'm learning to use stardard car shifting...3 or 4 actions to coodinate ;^).;if you hold the shift button down TOO long you get the slow curser dog & pony show, plus NO line!!
Bob Long
2006-05-13 01:05:48 UTC (almost 19 years ago)
I'm using 2.3.8. I must admit I did not find that tutorial explicit enough, or perhaps the method has changed. I had to do this:
1. One left click and release of the mouse at the point you want the start of the line.
2. Hold shift down. Hold control down as well if you want constrained angles.
3. Move the mouse - a guide line will be drawn - without clicking, to where you want the end of the line.
4. Click and release the mouse button. The line will be drawn. 5. Release the shift key.
MillTek
2006-05-13 01:54:47 UTC (almost 19 years ago)
I'm trying to get the lighting effect plugin to work. Even when I follow the various tutorials around teh net I cant seem to get it to 'see' the environment map and the bump map. I found one post that said that teh bump map had to be grayscale and I tried that with no luck. Does anyone have a good idea?
I'm using version 2.2.11
Jim
Simon Roberts
2006-05-13 02:36:47 UTC (almost 19 years ago)
thanks, yes, It's behaving now.
It takes a mouse click to indicate the starting point, and a shift-click to indicate the end. Holding shift in advance of the final click shows you where it will draw. Makes perfect sense now, but I was so expecting it to be a drag operation to draw the line (like it is when it's a freehand line) that I couldn't see the wood for the trees.
Thanks all, especially Marco for such prompt and persistent help.
Now I can just quietly put it behind me and slowly stop feeling really dumb!
Cheers,
Simon
out,
with
of the line.
angles. 3. Move the mouse - a guide line will be drawn - without clicking, to where
