gimp won't quit
gimp won't quit Never you mind 01 May 12:58
  gimp won't quit Andrea Sozzi 01 May 13:56
   gimp won't quit Never you mind 01 May 14:31
Never you mind
2006-05-01 12:58:44 UTC (almost 19 years ago)
gimp won't quit
I'm running gimp v2.2.10 on freeBSD v6 with KDE 3.5.2
gimp will let me close any window that I create but it won't let me close the windows that it opens when it opens, ie, "The Gimp" and "Layers, Channels, Paths etc". I see a message that says:
"Warning - KWin Window with title "The GIMP" is not responding. This window belongs to application gimp (PID=766, hostname=localhost). Do you wish to terminate this application? (All unsaved data in this application will be lost.)
It will not respond to the File-->Quit command either.
I'd like to be able close the program normally.
malcolm
Andrea Sozzi
2006-05-01 13:56:59 UTC (almost 19 years ago)
gimp won't quit
I had the same problem with gimp v2.2.10 on freeBSD v6.0 with Gnome 2.12.
- I had no problem after installing FreeBSD 6.0.
- The problem started after a GTK upgrade (i daily upgrade ports)
- The problem was fixed after Gimp upgrade to version 2.2.11
So, at least in my case, it seems that versions of GTK and Gimp shipped with FreeBSD 6.0 worked fine together; later there was an incompatibility which was quickly fixed (few days).
Maybe you upgraded GTK but not Gimp?
andrea
Never you mind
2006-05-01 14:31:38 UTC (almost 19 years ago)
gimp won't quit
I'm running gimp v2.2.10 on freeBSD v6 with KDE 3.5.2 gimp will let me close any window that I create but it won't let me close the windows that it opens when it opens, ie, "The Gimp" and "Layers, Channels, Paths etc". I see a message that says:
Maybe? Now I've upgraded Gimp and everything works nicely.
thanks
Malcolm
