Help with batch printing please?
Help with batch printing please? Simon Roberts 16 Apr 20:22
  Help with batch printing please? Alan Horkan 17 Apr 01:25
Simon Roberts
2006-04-16 20:22:44 UTC (about 19 years ago)
Hi All,
I'd like to be able to have gimp print something from a command line, so I can use it in a batch job.
Well, to back up a little, I guess what I want is to be able to print high quality graphics from a command-line but so far, the only thing I have that I'm aware of that does this on my Epson R200 printer is the GIMP.
What I'm trying to do is create a script to do it, but the docs seem a little thin (maybe I'm missing something). Anyway, I found something about script-fu, and tried to work from that. What I have doesn't work, and I don't seem to be able to find useful error messages (the console, after it fails, doesn't say anything helpful).
So, if anyone can suggest any or all of: 1) how do I debug this? 2) where can I find more information on scripting and 3) maybe tell me what is wrong with this, or what other command line utility I should use, I'd be very grateful.
Here's the non-working script: (define (gimp-batch-print filename)
(let* ((image (car (gimp-file-load RUN-NONINTERACTIVE filename filename)))
(drawable (car (gimp-image-get-active-layer image))))
(file_print_gimp RUN-NONINTERACTIVE image drawable "EpsonR200" "EpsonR200" raw 1 "1440 x 720 DPI Highest Quality" "Photo Quality Inkjet Paper"8 "Standard"
100.0 100.0 -1 -1 -1 1.0 1.0 1.0 1.0 1.0 0 2 100.0 100.0 "Six Color Photo"
"Adaptive Hybrid"
0)
(gimp-image-delete image)))
Which I put in my scripts directory and tried to run with: gimp -b gimp-batch-print ~/color.gif
TIA! Cheers,
Simon
"You can tell whether a man is clever by his answers. You can tell whether a man is wise by his questions." ? Naguib Mahfouz
___
Alan Horkan
2006-04-17 01:25:23 UTC (about 19 years ago)
On Sun, 16 Apr 2006, Simon Roberts wrote:
Date: Sun, 16 Apr 2006 11:22:44 -0700 (PDT) From: Simon Roberts
To: gimp-user@lists.xcf.berkeley.edu Subject: [Gimp-user] Help with batch printing please?
Hi All,
would still be worth including in your message ...
possibly use ImageMagick instead, it is designed for batch processing but I'd expect this to be possible
For starters you would need to define a value for RUN-NONINTERACTIVE somewhere, set it as 0 1 depending on what you want.
I found that really confusing and quite unclear when writeing my first scripts. I'd recommend hard coding everything and then cleanup the script once you have something which actually works (you probably do not really need to fill in any of those text strings for example).
at the end of the line you have an extra 8, that doens't look right, I'd at least expect a space after the quoted string
"Standard"
"Adaptive Hybrid"
0)
I assume you have stepped through the process manulaly and have the necessary gif and printer support setup.
Hope that helps
