color replacement
color replacement cheap_sunglasses 28 Mar 02:25
  color replacement Olivier Ripoll 28 Mar 12:14
color replacement Bob Long 28 Mar 03:01
cheap_sunglasses
2006-03-28 02:25:27 UTC (about 19 years ago)
color replacement
hi, i'm editing a scanned picture, and was wondering if anyone could tell me how to replace all colors, except black, with white....i traced over the lines on the original with my mouse, but the original scan pixels are still there. any advice would be very much appreciated. --
View this message in context: http://www.nabble.com/color-replacement-t1352868.html#a3621237 Sent from the Gimp User forum at Nabble.com.
Bob Long
2006-03-28 03:01:31 UTC (about 19 years ago)
color replacement
Use the "Select regions by color tool" and click on one of the black areas. You may need to adjust the threshold setting. Then Select|Invert. Then use the Fill tool (the bucket) - selecting "BG color fill" so it will fill with white, so long as your foreground and background colours are the default black and white - by clicking the image. You should now have only black and white areas. Of course, this means *everything* that is not black will be wiped out and replaced with white.
Olivier Ripoll
2006-03-28 12:14:16 UTC (about 19 years ago)
color replacement
Try "Colors->Threshold..." tool or "Colors->Levels...". Both should do this quite easily.
Best regards,
Olivier
