"script-fu-batching" how to merge and save?
"script-fu-batching" how to merge and save? ghostcorps 26 Mar 10:41
ghostcorps
2006-03-26 10:41:17 UTC (about 19 years ago)
Hi Guys
I have just started playing with script-fu as I need to run a batch on some icons for my X-server. I am using Spencer Kimballs alien-glow-logo.scm as my template and have hacked as much out of it as I can using the instructions here http://www.gimp.org/tutorials/Basic_Batch/ and here http://adrian.gimp.org/batch/batch-4.html as a guide. The script itself works (it would seem) but I cant get it to merge and save without user interaction. can anyone suggest where I am going wrong?
Thanks in advance =^_^=
********************************************* ; ghost-GLOW-cursor
; modified alien-glow-logo.scm Simulates an eerie glow around a cursor
(define (apply-ghost-glow-cursor-effect img logo-layer size glow-color) (let* ((border (/ size 4))
(grow (/ size 30))
(feather (/ size 4))
(width (car (gimp-drawable-width logo-layer))) (height (car (gimp-drawable-height logo-layer))) (glow-layer (car (gimp-layer-new img width height RGBA-IMAGE "ghost Glow" 100 NORMAL-MODE))))
(gimp-context-push)
(gimp-selection-none img) (script-fu-util-image-resize-from-layer img logo-layer) (gimp-image-add-layer img glow-layer 1) (gimp-layer-set-preserve-trans logo-layer TRUE) (gimp-edit-clear glow-layer)
(gimp-selection-layer-alpha logo-layer) (gimp-selection-grow img grow)
(gimp-selection-feather img feather) (gimp-context-set-foreground glow-color) (gimp-edit-fill glow-layer FOREGROUND-FILL) (gimp-selection-none img)
(gimp-context-set-foreground '(79 79 79))
(gimp-edit-blend logo-layer FG-BG-RGB-MODE NORMAL-MODE GRADIENT-SHAPEBURST-ANGULAR 100 0 REPEAT-NONE FALSE FALSE 0 0 TRUE
0 0 1 1)
(gimp-context-pop)))
(define (script-fu-ghost-glow-cursor-alpha img logo-layer size glow-color) (begin
(gimp-image-undo-group-start img) (apply-ghost-glow-cursor-effect img logo-layer size glow-color) (gimp-image-undo-group-end img)))
(script-fu-register "script-fu-ghost-glow-cursor-alpha" _"ghost _Glow..." "Create a cursor with a green glow" "Spencer Kimball" "Spencer Kimball" "1997"
"RGBA"
SF-IMAGE "Image" 0 SF-DRAWABLE "Drawable" 0 SF-ADJUSTMENT _"Glow size (pixels * 4)" '(50 2 1000 1 10 0 1)
SF-COLOR _"Glow color" '(00 80 00))
(script-fu-menu-register "script-fu-ghost-glow-cursor-alpha" _"/Script-Fu/Alpha to Logo")
; These 3 lines below are where I'm having trouble, I need to merge the two resulting layers and save.
(set! layer-to-save (gimp-image-flatten)) (set! drawable (car (gimp-image-get-active-layer image)) (gimp-file-save RUN-NONINTERACTIVE image drawable filename filename)))
(script-fu-register "script-fu-ghost-glow-cursor" _"ghost _Glow..." "Create a cursor with green glow" "Spencer Kimball" "Spencer Kimball" "1997"
SF-STRING _"Text" "GHOST" SF-ADJUSTMENT _"Font size (pixels)" '(50 2 1000 1 10 0 1)
SF-FONT _"Font" "Sans Bold" SF-COLOR _"Glow color" '(00 80 00))
(script-fu-menu-register "script-fu-ghost-glow-cursor" _"/Xtns/Script-Fu/Logos") ********************************************************
