help needed with menu tooltips
7 of 7 messages available
help needed with menu tooltips Sven Neumann 13 Mar 08:30
  help needed with menu tooltips Olivier Ripoll 13 Mar 14:38
   help needed with menu tooltips Sven Neumann 14 Mar 23:45
    help needed with menu tooltips Olivier Ripoll 15 Mar 14:13
     help needed with menu tooltips Olivier Ripoll 15 Mar 14:20
      help needed with menu tooltips Olivier Ripoll 15 Mar 18:29
       help needed with menu tooltips Sven Neumann 15 Mar 19:14
2006-03-13 08:30:31 UTC (about 19 years ago)
just wanted to point the people subscribed here to this thread over at the gimp-developer list:
http://lists.xcf.berkeley.edu/lists/gimp-developer/2006-March/015323.html
Since not much coding skills (if any) are needed to be able to help with this, I thought it would be appropriate to include the gimp-user list.
Olivier Ripoll
2006-03-13 14:38:48 UTC (about 19 years ago)
Hi Sven,
I have no possibility for CVS access (no internet at home, and filtered access at work). Is there a bug# where such text blobs could be posted/discussed ? If not, is posting to the mailing-list acceptable ?
Olivier.
2006-03-14 23:45:42 UTC (about 19 years ago)
Olivier Ripoll writes:
I don't have the resources to prepare such a list nor to merge the changes back into the source tree. For a review process it would perhaps be possible to somehow extract a list of the strings. But it should be a lot easier to just do these changes in the source code.
PS: CVS can be tunneled. But I don't want to get you into trouble...
Olivier Ripoll
2006-03-15 14:13:31 UTC (about 19 years ago)
Is there a possibility to use the latest tar.gz (2.3.7) and diff patches from it ?
Looking at the web cvs interface for gnome (this I can access, it is http), I can for instance see this recent change you did to the blur plugin: http://cvs.gnome.org/viewcvs/gimp/plug-ins/common/blur.c?r1=1.67&r2=1.68
You added a const gchar string const gchar *help =
"This plug-in blurs the specified drawable, using a 3x3 blur. " "Indexed images are not supported.";
So all is needed is to find a string to best describe the plugin, and store it in this help pointer, isn't it ?
It seems the help string can be multiline, am I correct on this ?
Best regards,
Olivier
Olivier Ripoll
2006-03-15 14:20:21 UTC (about 19 years ago)
Best regards,
Olivier
small correction: you also changed the call to gimp_install_procedure() to use the constant strings.
Olivier.
Olivier Ripoll
2006-03-15 18:29:21 UTC (about 19 years ago)
Olivier.
correction:
It is the other way around. You removed the strings. I had read the diff the wrong way.
So the tooltip is put in the N_(), correct ?
N_("Apply a 3x3 blurring convolution kernel"), (blur)
or
N_("Simulate movement by applying a blur effect"), (motion blur)
Best regards,
Olivier
2006-03-15 19:14:24 UTC (about 19 years ago)
Yes, but in the meantime Bill has done most of the plug-ins already. So it doesn't make sense to work from a tarball. You need CVS access.
