no raw in 2.2.7?-fixed
no raw in 2.2.7? Gracia M. Littauer 05 Mar 02:30
  no raw in 2.2.7? Carol Spears 05 Mar 03:50
  no raw in 2.2.7?-fixed Gracia M. Littauer 05 Mar 16:37
Gracia M. Littauer
2006-03-05 02:30:20 UTC (about 19 years ago)
no raw in 2.2.7?
I have the right raw files that worked w/previous versions, but no banana with 2.2.7
gimp is kind of useless if I can't open my pix files ;^(.
Carol Spears
2006-03-05 03:50:13 UTC (about 19 years ago)
no raw in 2.2.7?
i think that this plug-in is third party which means you need to get it and install it yourself.
maybe there is a whole fruit salad with a more current version of gimp though.
where did you get the version you are using from? was it different from where you got the others?
Gracia M. Littauer
2006-03-05 16:37:05 UTC (about 19 years ago)
I fixed the problem...properties had been reset..they looked OK till I went deeper & found where should have been.
Now if I figure out how to get add dir in the file list to work.
