arrow heads on lines
arrow heads on lines David Herring 02 Mar 15:36
  arrow heads on lines Harish Narayanan 02 Mar 17:07
   arrow heads on lines Rob 03 Mar 00:08
David Herring
2006-03-02 15:36:51 UTC (about 19 years ago)
I would like to be able to draw lines with arrow heads on the end of them, and for this to work with latest Gimp 2.2.10 on both linux and windows - what is the best solution ?
Thanks dave
Harish Narayanan
2006-03-02 17:07:33 UTC (about 19 years ago)
Are you restricted to using the GIMP?
The GIMP is primarily not a drawing tool. To do the task you just described, another program, Inkscape[1], fits the bill perfectly. It is compiled to work on GNU/Linux and MS Windows.
Harish
[1] http://www.inkscape.org/
Rob
2006-03-03 00:08:08 UTC (about 19 years ago)
And you can import some SVG (which Inkscape produces) back in to the gimp as a path. Not sure if the arrowheads will make it, but it's worth a try.
Harish
