Animations with translucent layers?
Animations with translucent layers? RalfGesellensetter 25 Feb 19:58
  Animations with translucent layers? Carol Spears 25 Feb 20:17
   Animations with translucent layers? RalfGesellensetter 25 Feb 20:30
  Animations with translucent layers? Sven Neumann 25 Feb 20:24
RalfGesellensetter
2006-02-25 19:58:35 UTC (about 19 years ago)
Hello all,
for several times I managed to create animations witb Gimp 2.2. Especially nice are web animations (GIF) which are easily done with GIMP.
Now, for the first time, GIMP's outcome is different from what I expect. Is it a feature or a bug that partly transparent layers are not shown in the animation preview box? I put an example to
http://www.skolelinux.de/~ralf/artwork/animations/
Cheers Ralf
Carol Spears
2006-02-25 20:17:49 UTC (about 19 years ago)
On Sat, Feb 25, 2006 at 07:58:35PM +0100, RalfGesellensetter wrote:
Hello all,
forgive me, i have not looked at the animation yet. even without looking (however) i can tell you that gif is either completely transparent or completely painted. there is no inbetween, unless you are one of those people who has purchased or obtained the propietary gif libraries which use (i think) something that i can only imagine to be a layered color set up.
the gifs that average users like you (maybe) and me have one 256 color palette. one of the color positions can be used for transparency leaving 255 colors and 1 no color. the industry gif has 256 of those palettes to work with and can show various amounts of transparency.
btw, 256x256 is something close to 16 million, which is the number of colors that a jpeg uses. jpeg however does not know transparency.
so there you go. it is not gimp that cannot make your animation transparent, it is the library they allow you to have and for your software to use to make and view gif with.
mng works. i am certain that one day a browser will be made that can display mng. especially if we can make a community of interested people who want to deliver free software to actual users. until such a software project exists, you can search the bug reports of the different browser projects to see what has happened there.
2006-02-25 20:24:35 UTC (about 19 years ago)
RalfGesellensetter writes:
All of the pixels in your partly transparent layers have an alpha value below 127, they are more transparent than opaque. Since GIF only supports binary transparency, these pixels all end up being transparent in the animation.
The Animation Playback plug-in simulates GIF transparency. If someone wants to come up with a patch that adds a check button to enable/disable this feature, that would be a welcomed contribution.
RalfGesellensetter
2006-02-25 20:30:09 UTC (about 19 years ago)
Am Samstag 25 Februar 2006 20:17 schrieben Sie:
Dear Carol,
thanks for your fast reply. If it was for exporting to GIF, I would have come to the same conclusion. But it is also within GIMP preview dialogue that the translucent gradients are not shown. I made sure in a 2nd trial that the layers themselves _are_ shown.
Regards Ralf
