Building multicolor gradients.
Building multicolor gradients. John R. Culleton 25 Feb 17:40
  Building multicolor gradients. Carol Spears 25 Feb 19:13
John R. Culleton
2006-02-25 17:40:45 UTC (about 19 years ago)
I want to build a gradient with three (or more) colors. Under 2.3.7 the "new gradient" routine only allows or a start and an end color.
What am I missing?
-- John Culleton
Carol Spears
2006-02-25 19:13:12 UTC (about 19 years ago)
What am I missing?
i think you are missing an idea. first add new segments. right click on the colors in the gradient editor. you can add segments in more than one way. i always have to read the options and think about it.
each segment has a right boundry, center boundry and left boundry.
the end and start in the dialog means the selected segments. to select a segment, right click on the center triangle of the segment you want. to select a group of segments, right click on either ending segment and (i think) shift click on the other ending segment.
the menu dialog uses right and left start points and this would be the right and left of the selected group of segments.
the interface with the gradient editor is somewhat complex, but so is editing gradients. after having been successful at this, i cannot think of a simpler way to do this.
i think i have a tutorial about it, i don't know if it answers your questions directly .....
[pause while reviewing old tutorials] http://carol.gimp.org/gimp2/artsy-fartsy/gradient/ sure, it is right there.
howcome i get so many web hits yet no one seems to know where my tutorials are?
