SVG Import Problem
SVG Import Problem Chris Spencer 31 Jan 03:46
  SVG Import Problem Sven Neumann 31 Jan 22:41
   SVG Import Problem Chris Spencer 01 Feb 02:45
    SVG Import Problem Jeffrey Brent McBeth 01 Feb 03:24
     SVG Import Problem Chris Spencer 01 Feb 14:27
Chris Spencer
2006-01-31 03:46:07 UTC (about 19 years ago)
SVG Import Problem
If I import an SVG file, the GIMP doesn't seem to rasterize using the correct resolution. No matter what resolution I specify, the layer will be generated with the proper dimensions, but the SVG image remains a fixed size regardless of the specified resolution.
For instance, say I import and image at 90 ppi and it gets rasterized as 744x1052. Now if I import the image again into the same file, but this time specify 300 ppi, it gets rasterized at 2480x3507, but the actual image in the new layer is the same size as the previous import. Only the layer sizes are different.
Is this a bug or am I missing something? It's driving me crazy. I'm using GIMP 2.2.10 on Fedora. Any help is appreciated.
Thanks, Chris
2006-01-31 22:41:01 UTC (about 19 years ago)
SVG Import Problem
Chris Spencer writes:
Could be a bug in GIMP (or rather the SVG plug-in) or in librsvg. Perhaps you can make the SVG available so that others can try if they are able to reproduce your problem?
Chris Spencer
2006-02-01 02:45:57 UTC (about 19 years ago)
SVG Import Problem
The problem's not specific to my SVG. Anything created with Inkscape (and therefore, probably SVG in general) is effected. It's almost like the "Resolution" field in the SVG Render dialog is simply being ignored.
Chris
2006-02-01 03:24:43 UTC (about 19 years ago)
SVG Import Problem
Hmm, I use SVG importing into GIMP several times a day (from Inkscape).
Looking at the import screen, I see the following
Width, Height, Units, X ratio, Y ratio, Link,
Resolution, Units,
Import Paths
Merge imported paths
Ahh, I see what you mean.
The resolution section does appear to be ignored.
Switch Width/Height to inches, and two in 2 for each Double the resolution (nothing happens) Switch the Width/Height units back to pixels (still same number of pixels as when started)
Jeff
Chris Spencer
2006-02-01 14:27:45 UTC (about 19 years ago)
SVG Import Problem
Resolution, Units,
Import Paths
Jeff
Well, at least I'm not going crazy ;) I've submitted the following bug report: http://bugzilla.gnome.org/show_bug.cgi?id=329411
Chris
