gradients and text
gradients and text Alex Feldman 13 Jan 14:02
  gradients and text Vytautas P. 13 Jan 14:13
gradients and text Michael Schumacher 13 Jan 14:34
Alex Feldman
2006-01-13 14:02:01 UTC (over 19 years ago)
gradients and text
Is there a way to apply a gradient to text, so only the letters get the color, not the background in the text layer?
Thanks.
Vytautas P.
2006-01-13 14:13:19 UTC (over 19 years ago)
gradients and text
Easilly. Select only the letters and apply gradient on them. Assuming text is on separate transparent layer, select that layer on Layers tab, and then Layers>Transparency>Alpha to selection.
Thanks.
2006-01-13 14:34:38 UTC (over 19 years ago)
gradients and text
Von: "Vytautas P."
Even faster: check "keep transparency" for the text layer in the layers dialog and apply the gradient as usual.
HTH, Michael
