Setting Desired Tool To Be Active When Starting GIMP
6 of 9 messages available
Gimp-user Digest, Vol 40, Issue 4 Michael Schumacher 05 Jan 12:08
Gimp-user Digest, Vol 40, Issue 8 Gabriel Acuna 07 Jan 07:01
  Gimp-user Digest, Vol 40, Issue 8 Axel Wernicke 07 Jan 08:32
20060104093315.D5CE9B3D3FF@... 07 Oct 20:17
  Gimp-user Digest, Vol 40, Issue 4 Gert Blij 05 Jan 08:38
   Pine.GSO.4.21.0601051848550... Owen Cook 05 Jan 08:53
    Setting Desired Tool To Be Active When Starting GIMP User1001 13 Jan 12:03
     Setting Desired Tool To Be Active When Starting GIMP Carol Spears 13 Jan 17:52
20060106200005.4D95DB3D31C@... 07 Oct 20:17
Gert Blij
2006-01-05 08:38:31 UTC (over 19 years ago)
Thanks Andrew,
I got that working for a rectangular copy and paste, but when I use the elipse select, the free select or the intelligent scissors, it cuts as per the created outline, but when I paste (into OpenOffice Writer) it pastes it as rectangular picture.
Is there any way that I can paste it as per the original cut?
TIA Gert
Date: Wed, 04 Jan 2006 10:31:16 +0100 From: Andrew
Subject: Re: [Gimp-user] Cutout and paste (Newbie question) To: gimp-user@lists.xcf.berkeley.edu Message-ID:
Content-Type: text/plain; charset=us-ascii; format=flowed
Gert Blij wrote:
I am (very) new to The Gimp and not a graphic designer. I
just want to use
some basic stuff and I am getting into it quite nicely.
However, for the life of me I can't find something that I
reckon is very
basic.
I want to cut out part of an image (rectangular, round or
oval, polygon,
etc) and copy and paste it to somewhere else. How do I do that?
For example:
First tool on toolbox (main gimp window) is rectangle select. Draw rectangular selection on picture. 'Edit' menu > Copy
Switch to target image
'Edit' menu > Paste Into
HTH
Andrew
2006-01-05 12:08:52 UTC (over 19 years ago)
Von: Owen Cook
On Thu, 5 Jan 2006, Gert Blij wrote:
Thanks Andrew,
probably not. The selection has bounds equal to its absolute width and height. This is what is copied accross
It should copy the pixels outside the selection as transparent, though. IIRC this did work at some, could be that it is broken in current versions of GTK+...
Gabriel Acuna
2006-01-07 07:01:27 UTC (over 19 years ago)
Can somebody tell me if, GIMP have the compression file option, beside the file format change. Thanks
----- Original Message ---
Axel Wernicke
2006-01-07 08:32:46 UTC (over 19 years ago)
Am 07.01.2006 um 07:01 schrieb Gabriel Acuna:
you can save images to filenames with the extension *.xcf.gz or *.xcf.bz2. Doing so causes GIMP to compress the image files.
lexA
Live is like a chocolate box, you never know what you wanna get... GPG Signatur auf http://wernicke-online.net/Impressum/ prüfen
User1001
2006-01-13 12:03:09 UTC (over 19 years ago)
How can I configure GIMP to start up with a specific TOOL active? I would like to establish "select rectangular region" as my default ACTIVE tool upon GIMP startup, but even if I have that selected, close out and reopen GIMP, it always starts up with the PAINTBRUSH tool activated.
Carol Spears
2006-01-13 17:52:58 UTC (over 19 years ago)
Preferences-->Save tool options on exit
then just make sure that you close gimp with rectangular select each time.
