drawing arrows with GFXMuse Tools
| 20051129162241.87457B4DA67@... | 07 Oct 20:17 | |
| drawing arrows with GFXMuse Tools | Michael J. Hammel | 29 Nov 17:38 |
| drawing arrows with GFXMuse Tools | sunita@chem.iitb.ac.in | 30 Nov 11:32 |
| drawing arrows with GFXMuse Tools | sunita@chem.iitb.ac.in | 01 Dec 10:35 |
| drawing arrows with GFXMuse Tools | sunita@chem.iitb.ac.in | 01 Dec 10:36 |
| drawing arrows with GFXMuse Tools | Patrick Shanahan | 01 Dec 14:11 |
On Tue, 2005-11-29 at 08:22 -0800, sunita@chem.iitb.ac.in wrote:
3. output of make
=================================================== [root@tyrosine gfxmuse-0.4]# make
making all in ./debug-d...
make[1]: Entering directory
`/home/sunita/softwares_pdf/gfxmuse-0.4/debug-d' rm -f debug.o gcc -c -O2 -march=i386 -mcpu=i686 -pipe -I. -I../hdrs-d -Ihdrs-d -I/usr/X11R6/include -Dlinux -D__i386__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -DFUNCPROTO=15 -DNARROWPROTO -g -Wall -DDEBUG -DGIMP12 -c debug.c cp libgmdbg.a ../lib-d
cp: cannot stat `libgmdbg.a': No such file or directory make[1]: *** [install] Error 1
make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory
`/home/sunita/softwares_pdf/gfxmuse-0.4/debug-d' make: *** [all] Error 2 ========================================================
First off, this is a *really* old version of the tools - see the web
site:
http://www.ximba.org/gfxmuse/download.html
If you're using GIMP 1.2 then you need the old version 2.0. If you're using GIMP 2.2 or later you need the beta version (which should work just fine) - 3.0.0B2.
I'm not sure what the problem is, but grab the new versions and try again. If it dstill doesn't work then email me and I'll see if I can help you get it compiled.
Gotta run - I'm late for a meeting at work.
Dear Michael,
I install version Muse tool 2.0, as the machine has GIMP 1.2. I installed it as root. It didn't give any problem.
In the last step of installation that is during make install ; bin-d is created but no executable files in it.
I suppose to transfer the executable files from bin-d folder to /home/sunita/.gimp-1.2/plug-ins. But there is no executable inside bin-d.
What should I do??
I am putting the output of 'make install' command so that it will be easier for you to findout the mistake.
[root@tyrosine GFXMuseTools]# make install
if [ ! -d bin-d ]; then mkdir bin-d; fi
mkdir -p ../cd/plug-ins
mkdir -p ../cd/data/gfxmt
cp -r html-d ../cd/data/gfxmt
mv ../cd/data/gfxmt/html-d ../cd/data/gfxmt/help
installing in ./debug-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/debug-d'
install in GFXMuseTools/enh/debug-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/debug-d'
installing in ./common-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/common-d'
cp libgfxm.a ../lib-d
install in GFXMuseTools/enh/common-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/common-d'
installing in ./arrows-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/arrows-d'
+ install -c -m 0444 GFXArrows ../../cd/plug-ins
install in GFXMuseTools/enh/arrows-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/arrows-d'
installing in ./cards-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/cards-d'
+ install -c -m 0444 GFXCards ../../cd/plug-ins
install in GFXMuseTools/enh/cards-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/cards-d'
installing in ./transform-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/transform-d'
+ install -c -m 0444 GFXTrans ../../cd/plug-ins
install in GFXMuseTools/enh/transform-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/transform-d'
installing in ./shapes-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/shapes-d'
+ install -c -m 0444 GFXShapes ../../cd/plug-ins
install in GFXMuseTools/enh/shapes-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/shapes-d'
installing in ./merge-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/merge-d'
+ install -c -m 0444 GFXMerge ../../cd/plug-ins
install in GFXMuseTools/enh/merge-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/merge-d'
installing in ./layers-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/layers-d'
+ install -c -m 0444 GFXLayers ../../cd/plug-ins
install in GFXMuseTools/enh/layers-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/layers-d'
installing in ./doc-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/doc-d'
install in GFXMuseTools/enh/doc-d done
make[1]: Leaving directory `/home/sunita/GFXMuseTools/doc-d'
First off, this is a *really* old version of the tools - see the web site:
http://www.ximba.org/gfxmuse/download.htmlIf you're using GIMP 1.2 then you need the old version 2.0. If you're using GIMP 2.2 or later you need the beta version (which should work just fine) - 3.0.0B2.
Gotta run - I'm late for a meeting at work. --
Michael J. Hammel |
The Graphics Muse | If you can't be kind, at least have the decency
mjhammel@graphics-muse.org | to be vague. http://www.graphics-muse.com
Dear users,
Finally I managed to install GFXMuse tool. It is working fine.
Thanks.
sunita
Dear Michael,
What should I do??
******************************************************************* [root@tyrosine GFXMuseTools]# make install if [ ! -d bin-d ]; then mkdir bin-d; fi mkdir -p ../cd/plug-ins
mv ../cd/data/gfxmt/html-d ../cd/data/gfxmt/help installing in ./debug-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/debug-d' cp libgmdbg.a ../lib-d
install in GFXMuseTools/enh/debug-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/debug-d' installing in ./common-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/common-d' cp libgfxm.a ../lib-d
install in GFXMuseTools/enh/common-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/common-d' installing in ./arrows-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/arrows-d' + install -c -m 0444 GFXArrows ../../cd/plug-ins install in GFXMuseTools/enh/arrows-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/arrows-d' installing in ./cards-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/cards-d' + install -c -m 0444 GFXCards ../../cd/plug-ins install in GFXMuseTools/enh/cards-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/cards-d' installing in ./transform-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/transform-d' + install -c -m 0444 GFXTrans ../../cd/plug-ins install in GFXMuseTools/enh/transform-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/transform-d' installing in ./shapes-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/shapes-d' + install -c -m 0444 GFXShapes ../../cd/plug-ins install in GFXMuseTools/enh/shapes-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/shapes-d' installing in ./merge-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/merge-d' + install -c -m 0444 GFXMerge ../../cd/plug-ins install in GFXMuseTools/enh/merge-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/merge-d' installing in ./layers-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/layers-d' + install -c -m 0444 GFXLayers ../../cd/plug-ins install in GFXMuseTools/enh/layers-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/layers-d' installing in ./doc-d...
make[1]: Entering directory `/home/sunita/GFXMuseTools/doc-d' install in GFXMuseTools/enh/doc-d done make[1]: Leaving directory `/home/sunita/GFXMuseTools/doc-d' *************************************************************************************First off, this is a *really* old version of the tools - see the web site:
Michael J. Hammel |
Dear users,
Thanks.
sunita
Dear Michael,
What should I do??
Michael J. Hammel |
* sunita@chem.iitb.ac.in [12-01-05 04:36]:
Good. Now be sure to post it _above_ an unnecessary full quote and, for sure, do _not_ provide the means to arrive at your solution. After all, no one here helped you and _nobody_ else will ever have the same problem.
