How to put an arrow mark using gimp
How to put an arrow mark using gimp sunita@chem.iitb.ac.in 29 Nov 14:01
  How to put an arrow mark using gimp Alexandre Prokoudine 29 Nov 14:05
How to put an arrow mark using gimp sunita@chem.iitb.ac.in 29 Nov 14:43
  How to put an arrow mark using gimp Patrick Shanahan 29 Nov 14:52
   How to put an arrow mark using gimp sunita@chem.iitb.ac.in 29 Nov 15:38
2005-11-29 14:01:49 UTC (over 19 years ago)
Dear gimp-users,
I want to put an arrow mark in a figure. I didn't find the option in gimp 1.2 version to put an arrow mark using gimp. I can draw a line. But I could not figure out how to put an arrow. I am new user of gimp.
While searching for it I came across Graphics Muse tool (http://www.graphics-muse.org/sw/gfxarrows.html) which provide plugin for drawing an arrow. I follow the instruction to install the plugin but could not do it.
Pls help me.
Your suggestion will be highly appreciated.
With best regards, sunita
2005-11-29 14:05:44 UTC (over 19 years ago)
Pls help me.
It is impossible to help you until you tell us what exactly goes wrong by installation.
Alexandre
2005-11-29 14:43:00 UTC (over 19 years ago)
Hi Alexandre,
I tried to install it as root in the Linux machine. I did not make any changes in the config.h. These are the steps specified in the README file.
0. Edit config.h - only a couple of items there you might need to change. 1. xmkmf
2. make Makefiles
3. make
4. make dist
1. output of xmkmf command =================================================== [root@tyrosine gfxmuse-0.4]# xmkmf
mv -f Makefile Makefile.bak
imake -DUseInstalled -I/usr/X11R6/lib/X11/config ===================================================
2. output of make Makefiles =================================================== [root@tyrosine gfxmuse-0.4]# make Makefile + rm -f Makefile.bak
+ mv -f Makefile Makefile.bak
imake -DUseInstalled -I/usr/X11R6/lib/X11/config -DTOPDIR=. -DCURDIR=. ===================================================
3. output of make =================================================== [root@tyrosine gfxmuse-0.4]# make
making all in ./debug-d...
make[1]: Entering directory
`/home/sunita/softwares_pdf/gfxmuse-0.4/debug-d' rm -f debug.o gcc -c -O2 -march=i386 -mcpu=i686 -pipe -I. -I../hdrs-d -Ihdrs-d -I/usr/X11R6/include -Dlinux -D__i386__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -DFUNCPROTO=15 -DNARROWPROTO -g -Wall -DDEBUG -DGIMP12 -c debug.c cp libgmdbg.a ../lib-d
cp: cannot stat `libgmdbg.a': No such file or directory make[1]: *** [install] Error 1
make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory
`/home/sunita/softwares_pdf/gfxmuse-0.4/debug-d' make: *** [all] Error 2 ========================================================
In the third of the installation I am getting the above error msg. How to get rid of this error?
Thanks for your help.
Sunita
Pls help me.
by installation.
Alexandre
Patrick Shanahan
2005-11-29 14:52:08 UTC (over 19 years ago)
* sunita@chem.iitb.ac.in [11-29-05 08:45]:
I do not know about the other commands, but you would _normally_ run 'make' and everything else except 'make install' as {USER}, then run 'make install' as root.
ps: PLEASE trim your quotes, http://www.netmeister.org/news/learn2quote.html
2005-11-29 15:38:21 UTC (over 19 years ago)
Hi
I am still having the problem. I have done as you have mentioned and ran following command as an user.
1. xmkmf 2. make Makefiles
3. make
While running make command as an user following error I got. ============================================================= [sunita@tyrosine gfxmuse-0.4]$ make
make[1]: Entering directory `/home/sunita/softwares_pdf/gfxmuse-0.4/debug-d' rm -f debug.o
gcc -c -O2 -march=i386 -mcpu=i686 -pipe -I. -I../hdrs-d -Ihdrs-d -I/usr/X11R6/include -Dlinux -D__i386__ -D_POSIX_C_SOURCE=199309L -D_POSIX_SOURCE -D_XOPEN_SOURCE -D_BSD_SOURCE -D_SVID_SOURCE -DFUNCPROTO=15 -DNARROWPROTO -g -Wall -DDEBUG -DGIMP12 -c debug.c cp: cannot stat `libgmdbg.a': No such file or directory make[1]: *** [install] Error 1
make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory `/home/sunita/softwares_pdf/gfxmuse-0.4/debug-d' make: *** [all] Error 2
How can I solve this problem??
Thanks for your suggestion.
sunita
ps: PLEASE trim your quotes, http://www.netmeister.org/news/learn2quote.html --
Patrick Shanahan Registered Linux User #207535 http://wahoo.no-ip.org @ http://counter.li.org HOG # US1244711 Photo Album: http://wahoo.no-ip.org/gallery2
