Deleting background color
2 of 3 messages available
E7F20B466062D511973800508B6... 07 Oct 20:15
  Deleting background color Carol Spears 25 Mar 17:04
   Deleting background color Patrick 25 Mar 20:50
Carol Spears
2002-03-25 17:04:55 UTC (about 23 years ago)
On 2002-03-25 at 0741.58 -0500, Cruz, John J typed this mail:
GIMP Users,
I recently competed a flyer for a relative that I had incorporated several clip-arts from the Internet. Many of them had a colored background that was not compatible with the white background I was using. I used Gimp to remove the background using the rectangle and Del button. This was very time consuming to say the least and prone to cutting away parts that I did not want too. I believe there is a better way to do this.
Somewhere I believe there is GIMP function that allows surrounding the selected art object about its perimeter and deleting everything outside it. Its name, use and location escapes me. Would someone run me through this process, please. Is there a better way of removing background color?
jjc
there are a few methods.
1) touch the background color with the magic wand. that will select the continuous area of color. then Edit ->Cut
2) Filters ->Colors ->Color2Alpha (on linux) might work also.
i have a question, where is the Del button?
Patrick
2002-03-25 20:50:13 UTC (about 23 years ago)
On Monday 25 March 2002 11:04 am, Carol Spears, was heard saying:
GIMP Users,
jjc
John,
I have also used the paint bucket to fill the offending color with a color of choice also. Pretty easy to do, if your picture has no missing pixels that might cause the color to go beyond your selected area. Of course, if it does, you can always hit the "Undo" button! :o)
I'll be Carol doesn't have that button either! ;o)
Patrick
