Howto composite over- and under-exposed images
Howto composite over- and under-exposed images Milan Knizek 20 Nov 09:23
  Howto composite over- and under-exposed images Bruno Postle 20 Nov 12:22
   Howto composite over- and under-exposed images Milan Knizek 20 Nov 18:41
Milan Knizek
2005-11-20 09:23:50 UTC (over 19 years ago)
is there an easy way to to take shadows from over-exposed image and highlights of under-exposed image and composite them together? (Assuming the two images are exactly the same, e.g. take from tripod or in a quick bracketing sequence.)
I know I could use manual masking of affected areas of one image, however, I would prefer to have GIMP create a mask for 'highlights' automatically (with soft transition to shadows) or even manually on a basis of a transition curve.
Thanks,
Milan
Bruno Postle
2005-11-20 12:22:42 UTC (over 19 years ago)
You can do it with layer masks:
http://www.panotools.info/mediawiki/index.php?title=Contrast_Blending http://www.erik-krause.de/blending/ http://www.luminous-landscape.com/tutorials/digital-blending.shtml
..or you can use an automated tool to build up a high dynamic range composite:
http://www.mpi-inf.mpg.de/resources/hdr/calibration/pfs.html
Cinepaint 0.20 has a plugin that does a similar thing.
Milan Knizek
2005-11-20 18:41:18 UTC (over 19 years ago)
Thanks for the extensive answer, I have been using cinepaint but was not aware about the new plugin.
Milan
