Font Problem,
Font Problem, Michael Luich 01 Nov 19:07
  Font Problem, Carol Spears 01 Nov 20:51
  Font Problem, Matt Gushee 01 Nov 23:55
Michael Luich
2005-11-01 19:07:11 UTC (about 20 years ago)
Font Problem,
Hey everyone,
I have a user who keeps getting : font '-Adobe-Helvetica-Bold-R-Normal-*-*-540-72-72-P-*-ISO10646-1' not found.
I can recreate it by trying to use the text tool to insert Helvetica bold.
RHEL 3 Everyhting seems to be default.
I can't seem to figure where it's trying to get this font from. I can't find anything like ISO10646 fonts although I have ISO8859 fonts. I'm sure I'm missing something simple.....
Thanks for the Help.
Michael Luich
Carol Spears
2005-11-01 20:51:49 UTC (about 20 years ago)
Font Problem,
which gimp are you using? and what does RHEL 3 mean?
gimp-2.whatever doesn't ask for fonts this way.
Matt Gushee
2005-11-01 23:55:24 UTC (about 20 years ago)
Font Problem,
How exactly do they "get" this message? Does it appear in a GIMP error dialog?
bold.
RHEL 3
Oh, well Red Hat would never configure anything wrong, so it must be user error ;-) (Can you tell I'm a *former* Red Hat user?)
can't find
Exactly. GIMP wants a Unicode font, but you don't have it.
I suspect the GIMP is trying to select fonts based on your locale settings. I'm not up to date with this stuff, so I can't give you anything authoritative, but a good starting point in diagnosis might be to check your language settings. E.g. what does
echo $LANG
tell you? If it says, e.g.,
en_US.utf8
then that probably accounts for GIMP wanting an iso10646 font. If that is the case, then try running the GIMP from the command line with
LANG=en_US gimp &
or perhaps
LANG=en_US.iso8859-1 gimp &
[there are several ways to spell the encoding; you might have to play with it a bit]
So, what if changing LANG does indeed solve the problem? There are several options:
1) Change the default LANG for your system ... this is the easiest solution, but could well cause problems with other applications. Best experiment thoroughly on yourself before inflicting this on anyone else.
2) Install/configure Unicode fonts as needed.
3) Create a wrapper script for the GIMP that does something like:
export LANG=en_US exec /usr/bin/gimp
And there are probably other solutions too ...
I'm sure I'm
RHEL is Red Hat Enterprise Linux.
There are several layers involved in font handling, so the error could be coming from a deeper level. However, I think you may be right anyway. The not-found font name is an XLFD (X Logical Font Descriptor); GIMP 2.x uses the newer Xft font mechanism. I don't think Xft uses XLFDs at all ... but then I really don't understand Xft, so I could easily be mistaken.
-- Matt Gushee
Englewood, CO, USA
