Lanczos interpolation method
9 of 9 messages available
Lanczos interpolation method cedric GEMY 11 Oct 01:38
  Lanczos interpolation method Jeffrey Brent McBeth 11 Oct 04:59
  Lanczos interpolation method Carol Spears 11 Oct 05:33
  Lanczos interpolation method Carol Spears 11 Oct 05:35
   Lanczos interpolation method Anthony DiSante 11 Oct 07:54
  Lanczos interpolation method Harish Narayanan 11 Oct 14:32
   Lanczos interpolation method Øyvind Kolås 13 Oct 12:56
    Lanczos interpolation method Harish Narayanan 13 Oct 15:13
    Lanczos interpolation method GSR - FR 13 Oct 18:03
cedric GEMY
2005-10-11 01:38:43 UTC (over 19 years ago)
Testing 2.3, i can there is new interpolation method called Lanczos. It is described as being better than cubic. Does anyboy know simply :) how it works with the picture ?
Cedric
2005-10-11 04:59:56 UTC (over 19 years ago)
Err, a quick summary (perhaps not simple) is that Cubic interpolation uses a third order polynomial to guess at values we don't have pixel samples for. Lanczos is from a family of interpolation schemes called windowed sinc.
The sinc function is defined as sin(x)/x (with it being 1 at x=0). It shows up a lot in signal processing, and can be shown to be "ideal" for interpolation (for some definition of ideal). Since the real world isn't ideal, and all trigonometric functions introduce ringing in a non-ideal world, they window the sinc function to limit how far out the ringing can go.
The sinc interpolation schemes tend to do a visually better job of interpolation at the cost of more processing time (but still less than a generic spline implementation).
I'm glad they added it. I probably won't be personally using it much, since my requirements are elsewhere, but it is a very useful thing to have available.
Incidentally, I know gamasutra had an article on sinc interpolation a few years back that should still be easy to find (I accidentally ran across it again a few weeks ago). Also, http://www.mathworld.com is a great resource for general math information.
Jeff
Carol Spears
2005-10-11 05:33:28 UTC (over 19 years ago)
i found this on wikipedia:
http://en.wikipedia.org/wiki/Lanczos_approximation
Carol Spears
2005-10-11 05:35:28 UTC (over 19 years ago)
what is more (or less) in my testing of cubic vs linear, cubic was slower not best. cubic produced a fuzzy image and linear seemed to produce the best resized image.
so if you are testing the different scaling options, i suggest you compare Lanczos with Linear.
Anthony DiSante
2005-10-11 07:54:14 UTC (over 19 years ago)
This is purely anecdotal, but for what it's worth, a while back I was trying to determine which scaling filter to use in a script to do batch-resizing with ImageMagick. I tested every filter with a couple of my digital photos as samples, in ImageMagick and PaintShopPro (IIRC), and to my eye Lanczos was the best; it was certainly at least *among* the best.
-Anthony DiSante http://encodable.com/
http://nodivisions.com/
Harish Narayanan
2005-10-11 14:32:49 UTC (over 19 years ago)
Actually, on a more generic level, is there some place (other than the source) where one can look up algorithm details pertaining to things like this and filters? If yes, awesome, if not, awesome, that will be a most informative documentation project to embark on.
Harish --
http://delineate.wahgnube.org
Øyvind Kolås
2005-10-13 12:56:54 UTC (over 19 years ago)
Comparisons of different interpolation methods (in this case not for scaling, but resampling for transformations like rotation.)
http://www.path.unimelb.edu.au/~dersch/interpolator/interpolator.html
/pippin
-- «The future is already here. It's just not very evenly distributed» -- William Gibson http://pippin.gimp.org/ http://ffii.org/
Harish Narayanan
2005-10-13 15:13:48 UTC (over 19 years ago)
Thank you, that was very informative.
Harish
-- http://delineate.wahgnube.org/
GSR - FR
2005-10-13 18:03:09 UTC (over 19 years ago)
pippin@gimp.org (2005-10-13 at 1256.54 +0200):
Some comments about uses:
http://www.softimage.com/Products/Other/Illusion/support/tipsntricks/lancos.htm
Some images comparing lanczos vs nearest for scaling down (and an hybrid system): http://imagebeat.com/mandala/thumbnail.html
GSR
