Gimp-2.3.4 problems
Gimp-2.3.4 problems Stephan Hegel 27 Sep 18:30
  Gimp-2.3.4 problems Carol Spears 27 Sep 20:36
   Gimp-2.3.4 problems Rikard Johnels 27 Sep 20:44
  Gimp-2.3.4 problems id6490 (sent by Nabble.com) 19 Nov 23:54
Stephan Hegel
2005-09-27 18:30:52 UTC (over 19 years ago)
Gimp-2.3.4 problems
Hi all,
I've installed gimp-2.3.4 right now and met another problem: all pull-down and pop-up menus do have a black background. Black fonts on black background is hard to read, I'm sure.
Within the terminal a few message like this pop up:
(gimp:23382): Gdk-WARNING **: gdk_window_set_back_pixmap(): pixmap must have a colormap
Any idea what went wrong here ?
Regards, Stephan.
p/s:
glib is 2.8.2
gtk+ is 2.8.3
Carol Spears
2005-09-27 20:36:16 UTC (over 19 years ago)
Gimp-2.3.4 problems
gtk+ is 2.8.3
this might be the problem. just a guess.
Rikard Johnels
2005-09-27 20:44:13 UTC (over 19 years ago)
Gimp-2.3.4 problems
gtk+ is 2.8.3
There has been several threads on different lists regarding this problem. It is a new feature in the gtk+ libs. And the software compiled against/using the old versions are not 100% compatible with the new ones.
One of the things being the black menues.
Suggestion; Revert to an older gtk+ lib.
2005-11-19 23:54:58 UTC (over 19 years ago)
Gimp-2.3.4 problems
How to fix "gdk_window_set_back_pixmap(): pixmap must have a colormap" black menus problem. Very simple.
Just add "/opt/gnome/lib/"
in "/etc/ld.so.conf"
and run "ldconfig".
Piece of cake, don't you?
id6490@yahoo.es Optimum Linux power. --
Sent from the Gimp User forum at Nabble.com: http://www.nabble.com/Gimp-2.3.4-problems-t351537.html#a1565853
