gimp-remote: Could not connect to the Gimp
gimp-remote: Could not connect to the Gimp Werner Franke 16 Sep 09:50
  gimp-remote: Could not connect to the Gimp Sven Neumann 16 Sep 22:10
Werner Franke
2005-09-16 09:50:21 UTC (about 20 years ago)
when I want to open a second picture in a already running gimp session I got the following message:
Could not connect to the Gimp. Make sure that the Toolbox is visible!
But the toolbox is on the current desktop on top. I use the command for the first picture:
and for the second:
I working on three PCs, all with SUSE 9.3 and mostly the same sw enwironment but the behavior of gimp is different.
AMD64: no Problems with gimp Notebook with PII: Problems with connect to gimp DELL GX110: Problems with connect to gimp
What can be the reason that gimp doesn't find it's own process ?
Any tips?
System: SUSE 9.3
GIMP-Version 2.2.4 (SUSE 9.3 rpm)
KDE 3.4.1
Thanks,
Werner
2005-09-16 22:10:05 UTC (about 20 years ago)
Werner Franke writes:
and for the second:
gimp-remote isn't the same process as gimp. I suggest you have a look at the source code of gimp-remote (it's found in the tools folder). That should give you an idea of how gimp-remote works and might enable you to find out why it isn't working for you.
