plug-in problems
6 of 7 messages available
plug-in problems Doug 08 Aug 15:44
  plug-in problems Carol Spears 08 Aug 18:17
42F8703D.7030804@onetel.com 07 Oct 20:17
  plug-in problems Doug 09 Aug 19:43
   plug-in problems michael chang 09 Aug 20:02
    plug-in problems Sven Neumann 09 Aug 22:02
    plug-in problems Doug 10 Aug 12:52
Doug
2005-08-08 15:44:09 UTC (over 19 years ago)
plug-in problems
Apologies for the Newbie question!
I'm using Gimp 2.2.4 and attempting to run the Colour Management plug-in, 'gimp-color-manager 0.1.0'. My OS is Mandrake Linux LE2005.
Following the INSTALL instructions I've configured, make'd and installed it. 'gimp-color-manager' appears in /usr/lib/gimp/2.0/plug-ins, (but not in ~/.gimp-2.2/plug-ins). However, I'm unable to activate it.
Gimp=> File=> Preferences=> Folders => Plug-ins shows /usr/lib/gimp/2.0/plug-ins as one of the Plug-In Folders. But Gimp=> Xtns=> Plug-in Browser doesn't find the colour manager plug-in and only searches among the plug-ins installed with the system.
There doesn't appear to be anything in Gimp 2.2.4 corresponding to the Xtns/Plugins Details or Plugin Description dialog as described in Gimp Help for incorporating new plug-ins.
What's missing or what am I doing wrong? I'd be grateful for any pointers.
Thanks
Doug
Carol Spears
2005-08-08 18:17:10 UTC (over 19 years ago)
plug-in problems
gimp has display filters that can adjust the display according to a monitor profile. View-->Display Filters. the problem is that you are on your own to find your monitor profile and install it there.
as far as color printing goes, gutenberg print (whatever gimp print has changed its name to) is on its way towards handling printer profilers if it does not handle them already.
Doug
2005-08-09 19:43:20 UTC (over 19 years ago)
plug-in problems
Carol,
Thanks for the help - I'll follow it up.
I still have a general newbie problem about installing plug-ins, however - I'm not sure that I've understood properly what to do. Can you advise me what I've done wrong or omitted here in trying to get 'gimp-color-manager' onto Gimp-2.2.4?
Doug
michael chang
2005-08-09 20:02:54 UTC (over 19 years ago)
plug-in problems
Are GIMP 2.0 plugins even _compatable_ with 2.2 plugins?
Also, is this a binary install, or a source-compile?
2005-08-09 22:02:18 UTC (over 19 years ago)
plug-in problems
michael chang writes:
Yes, binary and source compatible.
Doug
2005-08-10 12:52:25 UTC (over 19 years ago)
plug-in problems
source-compile from a tar.gz file
Doug
