"fit canvas to layers" needed after a crop
"fit canvas to layers" needed after a crop patman@aracnet.com 28 Jul 17:30
  "fit canvas to layers" needed after a crop Carol Spears 28 Jul 19:38
   "fit canvas to layers" needed after a crop patman@aracnet.com 28 Jul 20:00
patman@aracnet.com
2005-07-28 17:30:50 UTC (over 19 years ago)
Hi -
I used to crop, and the canvas size would change to match the crop size.
Now, I always have to select the image -> "fit canvas to layers" after each
crop to resize the canvas.
I must have changed some global option or something.
Anyone know what global setting or option I need to set?
Thanks ...
[sorry if this is a duplicate, no bounce and nothing seen in the archives, but I am now subscribed and I'm resending this.]
-- Patrick Mansfield
Carol Spears
2005-07-28 19:38:49 UTC (over 19 years ago)
On Thu, Jul 28, 2005 at 08:30:50AM -0700, patman@aracnet.com wrote:
Hi -
look in Dialogs -->Tool Options. there is a toggle for cropping the whole image or just one layer now. if you set it to crop the whole image, you will get the old behavior back.
patman@aracnet.com
2005-07-28 20:00:58 UTC (over 19 years ago)
Hi -
Okay ... I had tried crop and resize on the crop tool options with no change, but un-checking the "current layer only" gets me back to the behaviour I wanted, thanks!
