Howto write 8 Bit per pixel BMP files with gimp
Howto write 8 Bit per pixel BMP files with gimp Rainer Lehrig 21 Jul 16:26
  Howto write 8 Bit per pixel BMP files with gimp John R. Culleton 29 Jan 20:05
   Howto write 8 Bit per pixel BMP files with gimp Axel Wernicke 29 Jan 20:11
   Howto write 8 Bit per pixel BMP files with gimp JC Dill 29 Jan 20:45
Rainer Lehrig
2005-07-21 16:26:43 UTC (almost 20 years ago)
I have a software, that only works on Microsoft BMP files with 8 bits per pixel and 256 colour lookup table.
How can I create such files with gimp.
I already tried "Indexed" but without success.
Best regards: Rainer
John R. Culleton
2006-01-29 20:05:59 UTC (about 19 years ago)
What is the target program and what does it do? Perhaps there is another program that will accomplish your objective without the BMP restriction.
On Linux systems IMageMagick will convert almost any format to almost any format but I sense you are not on LInux.
Axel Wernicke
2006-01-29 20:11:13 UTC (about 19 years ago)
Am 29.01.2006 um 20:05 schrieb John R. Culleton:
ImageMagick is available for _many_ platforms.
JC Dill
2006-01-29 20:45:56 UTC (about 19 years ago)
For Windows users I know you can do this conversion with Irfanview. Irfanview can open/read almost any image file. You can save as windows bmp with 8bpp and 256 colors. If you have a lot of images to convert, open Irfanview thumbnails, select the images, then do a batch conversion (B).
jc
