select rect snap to corner
select rect snap to corner Tim E. Jedlicka - wrk 10 Jul 08:06
  select rect snap to corner Joe Carsto 10 Jul 16:59
  select rect snap to corner Sven Neumann 10 Jul 20:43
2005-07-10 08:06:00 UTC (almost 20 years ago)
I'm trying to use the "Select Rectangle" with a fixed aspect ratio. I would like it to snap to the corner of the image/layer. I have "snap to guides" set, but apparently the edges of an image don't have "default" guides. Is there a way to easily accomplish this?
I'm usually trying to crop a 4x6 image down to 3.5x5 maximizing as much of the original image as possible.
Thank you for a wonderful program.
----- Timothy Jedlicka, bonzo@lucent.com, 1-630-713-4436, AOL-IM=tjbonzo Network Entomologist, Lucent Technologies, LWS NOVE Lab Operations
Joe Carsto
2005-07-10 16:59:16 UTC (almost 20 years ago)
You could use the to crop your image. For example, if your original image is 900 X 600 pixels, you would set the canvas size to 750 X 525 pixels (make sure to unlock the width and height first). Then use the offset section of the dialog to "center" the original image in the new canvas.
HTH
2005-07-10 20:43:44 UTC (almost 20 years ago)
"Tim E. Jedlicka - wrk" writes:
The development version of GIMP has this feature.
