Gimp print
Gimp print Gary Montalbine 01 Jul 03:57
  Gimp print michael chang 01 Jul 13:21
   Gimp print Gary Montalbine 01 Jul 15:26
Gary Montalbine
2005-07-01 03:57:54 UTC (almost 20 years ago)
Gimp print
I have installed gimp 2.2.7 on Mandriva 2005LE. Gimp works fine except I do not have a print capability. I tried to install gimpprint 4.2.7 rpm however it wants libgimp 1.2.so. Print worked OK with an earlier 2.2 version of gimp and ML 10.1. I see there is now a gutenprint. Should I try to to configure gimpprint from source?
Comments appreciated.
Thanks,
Gary
michael chang
2005-07-01 13:21:08 UTC (almost 20 years ago)
Gimp print
You may want to ask the gimp-print list. Although it appears your RPM is the wrong one - it's a RPM intended for a 1.2 version of The GIMP. That's ancient. Is that the only 4.2.7 RPM you can find for your system?
Gary Montalbine
2005-07-01 15:26:20 UTC (almost 20 years ago)
Gimp print
I installed gutenprint 5.0 from Mandriva cooker and I am now able to print.
Gary
