Sony Ericsson Theme Creator
        Hello all,
I'm currently using the Theme Creator for my mobile phone on linux under
wine. It works great. I've been following the guides provided to create
the images necessary using the GIMP and have run into a small snag.
The guide is available here:
http://developer.sonyericsson.com/site/global/docstools/multimedia/p_multimedia.jsp
More specifically:
http://developer.sonyericsson.com/getDocument.do?docId=65049
You can see from that last link that they devote a whole section to
modifying images using the GIMP. The GIMP rocks and they know it!
The problem I'm having is that I want to generate 12bit images using the
instructions provided. I can follow the process through just fine.
However I do not understand how to obtain, or go about creating, the 4,
& 5bit palettes necessary to produce a 12bit output. You also need a
3bit but they provide this. It's a shame they didn't bother with the
rest.
I would also like to be able to automate this whole process, however, I
don't have the skills necessary (or the time) to create a Script-Fu
plugin. It would be really cool to be able to click "Script-Fu -> 12bit
Output". Is there anybody that would be able to help with this?
Thanks for your help.
Adam Cooper
