need help with scanned images
need help with scanned images ivan lópez 05 Jun 04:03
  need help with scanned images Carol Spears 05 Jun 05:37
ivan lópez
2005-06-05 04:03:51 UTC (almost 20 years ago)
hi,
I'm scanning a booklet with the intention of making a PDF version of it.
The booklet is printed on green paper and I'm having problems with the readability of the text. If you look at:
http://textzi.net/cosas/07.png
you'll see that the letters get a white edge around them that makes them a bit hard to read. Do you have any suggestions for changing this with the Gimp? Or should this be fixed directly when I scan the images? If so, how?
thanks in advance,
ivan
http://textzi.net
Carol Spears
2005-06-05 05:37:29 UTC (almost 20 years ago)
On Sat, Jun 04, 2005 at 09:03:51PM -0500, ivan l??pez wrote:
hi,
playing with the levels helped a lot.
then i went on to make a mask and apply this to the original.
after only a few minutes with the image, it seems to be easier to read: http://carol.gimp.org/files/07.xcf
