Overlaying and scaling images
Overlaying and scaling images Dylan 02 Jun 00:38
  Overlaying and scaling images Jeffrey Brent McBeth 02 Jun 00:51
Dylan
2005-06-02 00:38:23 UTC (almost 20 years ago)
Hi All,
I'm trying to overlay images of maps onto aerial protographs. Using the photo as a background, I need to scale and rotate the map image so that the two line up. Is this possible with the Gimp? What approach should I use?
If it's not feasable with Gimp, does anyone know any (Linux) software which would be suitable?
Cheers
Dylan
2005-06-02 00:51:06 UTC (almost 20 years ago)
On Wed, Jun 01, 2005 at 11:38:23PM +0100, Dylan wrote:
Hi All,
Definitely possible and feasable. As long as you have a simple perspective transform in your images. Once things like WGS'84 and other coordinate systems rear their head, the best bet is something made for this like GRASS.
Anyway, the main tool you would be looking for is the Rotate, Scale, Shear, and Perspective tools (Shift-R, Shift-T, Shift-S, Shift-P by default) Perspective and Rotate will probably be the most useful.
I've done it, and it works as long as your data isn't too distorted. Don't try anything like the overlays Google Maps does, though, you would definitely need something like GRASS then.
Jeff
