Focus
Focus Sven Neumann 31 May 17:47
Focus Alexander Rabtchevich 31 May 18:36
Focus Alexander Rabtchevich 01 Jun 07:43
2005-05-31 17:47:55 UTC (over 19 years ago)
Focus
Richard Nagle writes:
What I need to do is to refocus the image, or resharpen, however, unsharpen mask made it worst.
Are there some plug ins to use, or some methods ?
Have you tried http://refocus.sourceforge.net/ yet?
2005-05-31 18:36:59 UTC (over 19 years ago)
Focus
I'd recommend you the refocus plugin (do not mess it with refocus-it, which is useless). The source code can be find at http://refocus.sourceforge.net/
The compiled Windows plugin is
http://distantland.hp.infoseek.co.jp/gimp/plug-ins/files/refocus-0.9.0.zip The sharpness can be changed with change of correlation value.
2005-06-01 07:43:07 UTC (over 19 years ago)
Focus
Sorry, I don't know.
If there is a MAC conference on GIMP (as it is for Windows), you can ask somebody there to compile the plugin for you.
is there a Mac OS version compiled? thanks-
