plug-in-sobel not consistent
7 of 7 messages available
plug-in-sobel not consistent MrShark 27 Dec 22:50
  plug-in-sobel not consistent MrShark 28 Dec 13:01
   plug-in-sobel not consistent programmer_ceds 29 Dec 16:53
    plug-in-sobel not consistent MrShark 29 Dec 17:05
     plug-in-sobel not consistent MrShark 29 Dec 17:19
      plug-in-sobel not consistent programmer_ceds 29 Dec 18:06
       plug-in-sobel not consistent MrShark 29 Dec 18:25
MrShark
2021-12-27 22:50:41 UTC (almost 4 years ago)
I am developing my first script-fu. In my script I am using plug-in-sobel to detect edges. I was wondering about the result of the plug-in, because it differs from the result I get, when I execute the sobel-filter directly from the Filter menu (Filter > Edge detection > Sobel ...).
My script-fu-cartoon looks like (define (script-fu-cartoon
drawable)
; Create a new layer (define sobel-layer (car (gimp-layer-copy drawable 0))) (gimp-item-set-name sobel-layer "sobel operator") (gimp-image-insert-layer img sobel-layer 0 0)
; Execute sobel-operator (plug-in-sobel RUN-NONINTERACTIVE img sobel-layer TRUE TRUE TRUE)
(gimp-displays-flush) )
(script-fu-register "script-fu-cartoon" "/Filters/Artistic/Cartoon..."
"todo description"
"todo author"
"todo copyright"
"todo date"
SF-IMAGE "Image" 0
SF-DRAWABLE "Current Layer" 0
I am executing plug-in-sobel with the same parameters as from the GUI. But the output differs. Why is this so?
Best regards Pascal
MrShark
2021-12-28 13:01:20 UTC (almost 4 years ago)
To make my question more clear I added two images which show the different outputs. I am using the same parameters on both ways to apply the filter.
drawable)
"todo description"
"todo author"
"todo copyright"
"todo date"
SF-IMAGE "Image" 0
Best regards Pascal
2021-12-29 16:53:29 UTC (almost 4 years ago)
It looks like your script is running the built-in Sobel plug-in but when you go via "Filters/Edge Detect/Sobel..." you are getting a GEGL version that has extra parameters - for blending mode and opacity.
MrShark
2021-12-29 17:05:27 UTC (almost 4 years ago)
Is there any way to use the GEGL version in my script? I was also using the plug-in-edge with its sobel operator, but the result is also a different one: (plug-in-edge 1 img sobel-layer 1 0 0)
MrShark
2021-12-29 17:19:10 UTC (almost 4 years ago)
As discussed here http://gimpchat.com/viewtopic.php?f=9&t=18040 there is no way to call GEGL functions from script-fu. GEGL functions can only be called in python scripts.
There is an open issue for this feature: https://gitlab.gnome.org/GNOME/gimp/-/issues/1686
2021-12-29 18:06:48 UTC (almost 4 years ago)
You could switch to using Python - much more pleasant to program in (without having to use reverse Polish notation) and more powerful.
Note, however, that GIMP Python scripting changes dramatically between GIMP V2.10 and V2.99/3 - although the core of your code would remain unchanged between the versions.
MrShark
2021-12-29 18:25:28 UTC (almost 4 years ago)
Thanks for your update. I'll give it a try and write my script with python.
