Zoom motion and Colorise (Colorize)
Zoom motion and Colorise (Colorize) BobArt 07 Nov 13:58
  Zoom motion and Colorise (Colorize) BobArt 08 Nov 00:26
   Zoom motion and Colorise (Colorize) rich404 08 Nov 09:42
    Zoom motion and Colorise (Colorize) BobArt 08 Nov 22:02
  Zoom motion and Colorise (Colorize) shallwani 18 Nov 11:06
2020-11-07 13:58:46 UTC (over 4 years ago)
I have noticed a difference between these functions (Zoom motion and Colorise (Colorize)) between 2.10 and 2.8. I much prefer the results in 2.8, but now that I have saved some projects in 2.10, I cannot open them in 2.8. Is there any way I can extract the scripts from 2.8 and add them to 2.10?
2020-11-08 00:26:47 UTC (over 4 years ago)
Actually, I mean 2.8 Colorify.
How can I get that into 2.10?
2020-11-08 09:42:49 UTC (over 4 years ago)
No mention of OS so assuming Windows (64 bit)
Colorify is still there, but is disabled not to show in the menu structure. Gimp 2.10 has a search function, press the forward slash key (/) and type in part of a search term. https://i.imgur.com/hgjRqu8.jpg Click on an entry to get the filter.
If you want the old Gimp 2.8 colorify plugin (64 bit), attached in the zip. Unzip put it in your Gimp user profile C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\plug-ins Find it bottom of the Colors menu.
There is no equivalent of 'Zoom Motion' GEGL procedure in Gimp 2.8
Backward Compatibility, 2.10 xcf to 2.8 xcf, is largely a layer modes exercise. Look for the legacy icon and a (l) suffix on the mode name.
Saving as a xcf will indicate if it is compatible: https://i.imgur.com/HM6Sam1.jpg As with most thing Gimp, there is a plugin to help. Not perfect but often works. That is in zip as well. Find that one in the Tools menu.
2020-11-08 22:02:09 UTC (over 4 years ago)
Yes. I've just discovered it's a plug-in. Downloaded and installed.
Happy bunny. Works a treat.
Shame about the Zoom. 2.10 is a bit "hard", but I can live with that. Thanks for your help!
2020-11-18 11:06:59 UTC (over 4 years ago)
10-Kを理解する
含まれる情報の深さと性質により、10-Kは非常に長く、通常は複雑です。しかし、投資家は、これが公開会社が毎年発行できる最も完全で重要な文書の1つであることを理解する必要があります。 10-Kから収集できる情報が多ければ多いほど、会社について理解を深めることができます。
政府は、投資家が情報に基づいた投資決定を下せるように企業に関する基本的な情報を入手できるように、企業に10-Kフォームの発行を義務付けています。このフォームは、会社が行うすべてのことと、会社が直面しているリスクの種類についてより明確なアイデアを提供します。
forex trading signals free 10-Kは、EDGARSECデータベースを介した会社の検索機能を使用して取得することもできることを知っている投資家。 10-Kには、5つの個別のセクションが含まれています。
無料の外国為替シグナル
ビジネス。これは、製品やサービス(つまり収益の方法)を含む、会社の中核事業の概要を提供します。 リスクは通常、重要度の高い順にリストされています。彼らは、会社が直面している、または将来直面する可能性のあるすべてのリスクを提示しました。 選択された財務データ。このセクションでは、過去5年間の会社に関する特定の財務情報について説明します。このセクションでは、会社の最近の業績の概要を説明します。 財政状態および活動の結果の管理による議論および分析。 MD&Aとも呼ばれ、前年度の業績を説明する機会となります。このセクションでは、会社は独自の言葉でストーリーを語ることができます。 財務諸表および追加データ。これらには、損益計算書、貸借対照表、キャッシュフロー計算書など、会社の監査済み財務諸表が含まれます。このセクションには、監査の範囲を証明する会社の独立監査人からの手紙も含まれています。 宣言10-Kには、会社のCEOおよびCFOからの署名入りの手紙も含まれています。その中で、経営幹部は、10-Kに含まれる情報が正確であることを誓います。これらの手紙は、敗北後の会計詐欺を含むいくつかの有名な事件の後に要件になりました。 外国為替取引シグナル無料
10-Kの場所
10-Kアプリケーションは公開されている情報であり、さまざまなソースからすぐに入手できることに注意してください。実際、大多数の企業は、自社のWebサイトの「投資家向け広報」セクションにそれらを含めています。 10-Kに含まれる情報は転送が難しい場合がありますが、含まれる情報のレイアウトとタイプについて投資家がよく知っているほど、最も重要な詳細を特定しやすくなります。 free forex signals
10-Kは、国営企業が財務結果について毎年発行する包括的なレポートです。 このレポートは、米国証券取引委員会(SEC)によって要求されており、年次レポートよりもはるかに詳細です。 10-Kの情報には、社史、財務諸表、1株当たり利益、およびその他の関連データが含まれます。 10-Kは、投資家が投資について重要な決定を下すための便利なツールです。 10-Kアプリケーションの締め切り
10-Kの申請期限は、会社の規模によって異なります。 SECによると、7億ドル以上の価値のある上場株式は、会計年度末から60日以内に10-Kを提出する必要があります。変動価格が7500万ドルから7億ドルの企業は、75日ですが、7500万ドル未満の企業は90日です。
フォーム10-Qおよび8-K 10-Kに加えて、SECは、国営企業に10-Qおよび8-Kフォームを定期的に提出することを要求しています。 https://www.freeforex-signals.com/
フォーム10-Qは四半期ごとにSECに提出する必要があります。このフォームは、会社の業績に関する包括的なレポートであり、会社の財政状態に関する関連情報が含まれています。 10-Kとは異なり、10-Qの情報は通常監査されません。 10-Kは第4四半期に提出されるため、同社は年に3回提出するだけで済みます。 https://www.freeforex-signals.com/
フォーム8-Kは、企業が株主に通知する必要のある重要なイベントを発表するときにSECによって要求されます。これらのイベントには、販売、買収、上場廃止、退任、役員選挙、会社のステータスや支配権の変更、破産、取引に関する情報、資産、その他の関連ニュースが含まれますが、これらに限定されません。
