Clone Tool Issue
Clone Tool Issue SHAUN LORENZ TAN 11 May 04:09
  Clone Tool Issue Liam R E Quin 11 May 05:57
   Clone Tool Issue Ofnuts 11 May 09:34
SHAUN LORENZ TAN
2020-05-11 04:09:41 UTC (almost 5 years ago)
Clone Tool Issue
Good afternoon sir/ma'am,
I would like to ask for help regarding the clone tool in the GIMP app. I observed that the clone tool does not seem to work anymore right after i used the text tool. Do you happen to know how can i troubleshoot this. Thank you and God bless!
CONFIDENTIALITY NOTICE: This email, including any attachments, is only
intended for the use of the addressee. It may contain confidential or
privileged information, including personal data, which should not be used
or disclosed without proper authorization. If you received this email in
error, contact the sender immediately and permanently delete it from your
system. Unless otherwise indicated, the contents of this email do not
necessarily reflect the views or policies of the Ateneo de Manila
University.
Data privacy issues should be directed to the University Data
Protection Office at the following contact information: questions or
clarifications (info.udpo@ateneo.edu );
complaints or security incidents involving personal data
(alert.udpo@ateneo.edu ).
Liam R E Quin
2020-05-11 05:57:18 UTC (almost 5 years ago)
Clone Tool Issue
used the text tool.
Note that the text tool creates a new kayer and makes it active. So you will need to go to the layers dialogue and choose the layer you want to clone from.
slave liam
2020-05-11 09:34:19 UTC (almost 5 years ago)
Clone Tool Issue
used the text tool.
And the text layer is typically smaller than the canvas, so it is likely that the OP is trying to clone outside of that layer's boundary.
