Installing Gimp 2.10.18 on Mac OS using macports
Installing Gimp 2.10.18 on Mac OS using macports Luthien 03 May 12:54
  Installing Gimp 2.10.18 on Mac OS using macports Luthien 03 May 15:47
   Installing Gimp 2.10.18 on Mac OS using macports Tres Finocchiaro via gimp-user-list 07 May 17:29
  Installing Gimp 2.10.18 on Mac OS using macports Cliff Pratt via gimp-user-list 07 May 23:12
2020-05-03 12:54:50 UTC (almost 5 years ago)
Since there's still no official Mac OS build for Mac OS available, I first tried Partha's build.
I'm glad that he got around to making those available again.
However, I found that especially using G'Mic is very slow on that build - much slower than they older 'official' 2.10.14 version of Gimp was. So, I looked for other options.
Homebrew still only provides 2.10.14 as well, but apparently MacPorts does offer v. 2.10.18, so I gave that a try.
Short version: it works fine, but building will take some time. Also, the installed version runs on XQuartz, like in the old days ;) - key combinations all use the Control, not the Command key. You can change that in the keyboards shortcuts config. G'Mic is also fine, and is definitely as fast as it was on v. 2.10.14.
Slightly longer version: for instructions on how to install MacPorts, see the macports website. There are .pkg packages for all recent versions of Mac OS.
You will also need to have the XCode command line tools installed - macports will probably prompt you if it can't find it.
And: be patient ... MacPorts builds all the required libraries, and therefore it takes serious time. Using a 2019 MBP (2.3 GHz 8-Core Intel Core i9), the whole exercise lasted about an hour - especially the building gcc10 step. Just wait until it's done.
If all goes well, you'll end up with a directory called 'MacPorts' in the Application folder; and in there a tiny Gimp.app package, with the bulk of the code installed in /opt/local.
Note that, contrary to Homebrew, MacPorts requires sudo permissions to install software.
I think it's usable, but I still hope the official version for mac will come out (no XQuartz, the menu in the usual top-bar pace, and having the CMD key combinations).
I hope this is of some use to others!
Lúthien
Luthien (via www.gimpusers.com/forums)
2020-05-03 15:47:25 UTC (almost 5 years ago)
Incidentally, if I could help out with creating the official build for Mac OS, I'd be happy to.
I already tried to find some instructions how to do that, but the only thing that I could find is the "Hacking: Building/Mac OSX" page on wiki.gimp.org, which seems pretty incomplete and outdated. One would think that there should be something other than that, or has only one person done all the mac os builds all those years?
Just wondering :)
2020-05-07 17:29:25 UTC (almost 5 years ago)
Some great dialog about this over on this thread: https://mail.gnome.org/archives/gimp-user-list/2020-April/msg00142.html
I volunteered to help but have been backlogged. XQuartz is unusable in my opinion. It's a nice option, but for productivity software I've steered away from it. Anyway, the Homebrew stuff is documented (with links) on that thread.
- Tres.Finocchiaro@gmail.com
I'd be happy to.
that I could find is the "Hacking: Building/Mac OSX" page on wiki.gimp.org ,
those years?
Just wondering :)
-- Luthien (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
2020-05-07 23:12:09 UTC (almost 5 years ago)
Just out of interest, (I'm not a Mac user), would it take as long if you were to rebuild? In other words, does the process always rebuild everything or is it cleverer than that?
Cheers,
Cliff
Partha's build.
other options.
2.10.14.
until it's done.
software.
Lúthien
My Amazon author page : https://amazon.com/author/cliffpratt
My Facebook author page : https://www.facebook.com/cliffprattauthor
My Search on Kobo : https://www.kobo.com/search?query=Cliff+Pratt
