SVG to PNG using a script
15 of 15 messages available
SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 19:47
  SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 19:48
  SVG to PNG using a script Guy Stalnaker via gimp-user-list 21 Apr 19:53
   SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 19:59
  SVG to PNG using a script Liam R E Quin 21 Apr 20:24
   SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 20:36
    SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 20:39
     SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 20:46
     SVG to PNG using a script Liam R E Quin 21 Apr 22:26
      SVG to PNG using a script Tres Finocchiaro via gimp-user-list 23 Apr 15:51
       SVG to PNG using a script Tres Finocchiaro via gimp-user-list 23 Apr 17:39
        SVG to PNG using a script Tres Finocchiaro via gimp-user-list 23 Apr 17:51
         SVG to PNG using a script Tres Finocchiaro via gimp-user-list 23 Apr 18:00
  SVG to PNG using a script Michael Schumacher 21 Apr 20:57
   SVG to PNG using a script Tres Finocchiaro via gimp-user-list 21 Apr 21:04
2020-04-21 19:47:17 UTC (almost 5 years ago)
I'm looking into Gimp as a viable scripting solution for a project however most of the scripting references I'm finding are either sparse or dated.
I was wonder if there was a way to utilize Gimp's scripting system to convert an SVG to a PNG?
The best resource I've found is here however, attempts to run this on my machine are failing using GIMP 2.1.0.
http://www.jasonhardin.com/programming/2012/08/23/Gimp-svg-to-png-script/#disqus_thread
The script I'm running: gimp -i --batch='(svg-to-raster "src.svg" "dst.png" 72 0 0)' --batch='(gimp-quit
0)'
Unfortunately it throws the following error: batch command experienced an execution error: Error: eval: unbound variable: file-svg
I'm using MacOS to write the script, but the target platform is Windows.
I understand there are many other tools for performing this conversion (and I'm leveraging these tools in other parts of code) but I was hoping to write this as a fallback for this particular system.
Best regards,
-Tres
- Tres.Finocchiaro@gmail.com
2020-04-21 19:48:51 UTC (almost 5 years ago)
Apologies, typo:
Should have been: Error: eval: unbound variable: *svg-to-raster *
The script I'm running: gimp -i --batch='(svg-to-raster "src.svg" "dst.png" 72 0 0)' --batch='(gimp-quit 0)'
Best regards,
-Tres
2020-04-21 19:53:59 UTC (almost 5 years ago)
Tres,
Several perhaps better options are tools intended for command line use:
https://www.imagemagick.org/script/download.php
Or, for considerably more sophisticated image work (with correspondingly more detailed and opaque documentation) G'MIC (which also has a builtin tool for use inside GIMP usually packaged with GIMP):
https://gmic.eu/download.shtml
Both of these tools can be scripted.
Regards.
Guy Stalnaker jimmyg521@gmail.com
On Tue, Apr 21, 2020 at 2:47 PM Tres Finocchiaro via gimp-user-list < gimp-user-list@gnome.org> wrote:
0)'
Best regards,
-Tres
- Tres.Finocchiaro@gmail.com _______________________________________________ gimp-user-list mailing list
2020-04-21 19:59:07 UTC (almost 5 years ago)
Hmm... I'm not sure why the scripting system is continuously dismissed as a viable solution. Is your answer that it's not viable. Requoting:
On Tue, Apr 21, 2020 at 3:54 PM Guy Stalnaker wrote:
Tres,
Regards.
0)'
Best regards,
-Tres
Liam R E Quin
2020-04-21 20:24:29 UTC (almost 5 years ago)
On Tue, 2020-04-21 at 15:47 -0400, Tres Finocchiaro via gimp-user-list wrote:
Yes, from python, perl or scheme (script-fu).
there's also batch mode add-ons such as phatch.
You might prefer to use Inkscape for this one - it can do this in the command-line.
Hoping you mean 2.10.18
We are a release behind n the Mac because we don't have a Mac maintainer right now.
For the error you're getting try changing file-svg to file-svg-save maybe.
slave
Liam Quin - https://www.fromoldbooks.org/
Slave in full-time voluntary servitude
2020-04-21 20:36:27 UTC (almost 5 years ago)
I'm confused, I'm attempting to use the gimp command line, is it no longer supported? Why am I being told to use other tools still?
This is a specific attempt to use Gimp for a task. No additional software installed. If Gimp ships with a usable version of python in a reliable location, I'd be happy to leverage that, but the question is in regards to a target system with only Gimp installed, assuming it doesn't have Inkscape, ImageMagick Python or Perl.
I'm asking how to use the gimp command line only.
slave
2020-04-21 20:39:29 UTC (almost 5 years ago)
Liam,
After re-reading your post, is it safe to assume my original question was written in scheme/script-fu?
If so, can someone direct me how to get a list of scheme commands that can be executed from a vanilla gimp install?
slave
2020-04-21 20:46:24 UTC (almost 5 years ago)
Are my examples written in Carrette’s SIOD instead of TinyScheme? Was the svg-to-raster command removed in a certain version (or perhaps not distributed with the macOS build?).
This seems like it's a fairly simple script, but the fact that it doesn't work leads me to believe something has changed since the linked article was written.
On Tue, Apr 21, 2020 at 4:39 PM Tres Finocchiaro wrote:
Liam,
On Tue, Apr 21, 2020 at 4:36 PM Tres Finocchiaro < tres.finocchiaro@gmail.com> wrote:
slave
2020-04-21 20:57:38 UTC (almost 5 years ago)
0)'
What you found is just the command line being used to run a custom script someone wrote - I assume this was available from one of the now-defunct links in the message you linked to.
In short: what you have found and posted is not a complete script, not by far.
In principle, the actual script was likely similar to the examples in https://www.gimp.org/tutorials/Basic_Batch/ - with different parameters, though, as it only really needs to open a file and export it with a different file name.
2020-04-21 21:04:35 UTC (almost 5 years ago)
Michael,
You're completely right, the web archive of that original post has it for download. Here's the web archive article, which specifically mentions downloading svg-to-raster.scm.
https://web.archive.org/web/20140214102644/http://porpoisehead.net/mysw/index.php?pgid=gimp_svg
Fortunately, web archive had a copy of the scheme source. I've re-hosted it here: https://gist.github.com/tresf/c06aac6ceb51b86f328c3655fb503efe
I'll continue down this path and share my progress. Thanks kindly!
0)'
GPG: 96A8 B38A 728A 577D 724D 60E5 F855 53EC B36D 4CDD _______________________________________________ gimp-user-list mailing list
Liam R E Quin
2020-04-21 22:26:21 UTC (almost 5 years ago)
On Tue, 2020-04-21 at 16:39 -0400, Tres Finocchiaro wrote:
Liam,
Probably the script you were running, the one you didn't includeand got from Web archive, was in Scheme, yes.
It's a text file, and the likely error from the message is that it calls file-png to export, and not file-png-save.
Help->Procedure Browser
slave liam
Click here to have the slave beaten.
2020-04-23 15:51:35 UTC (almost 5 years ago)
A one-liner using Gimp and no other tools:
./gimp -i -b '(let* ((image (car (file-svg-load RUN-NONINTERACTIVE *"input.svg"* "" *72* (- 0 *400*) (- 0 *600*) 0))) (drawable (car (gimp-image-get-active-layer image)))) (plug-in-autocrop RUN-NONINTERACTIVE image drawable) (gimp-file-save RUN-NONINTERACTIVE image drawable *"output.png"* *"output.png"*) (gimp-image-delete image))' -b '(gimp-quit 0)'
Where:
- "input.svg" is the source file name - 72 is the output resolution in pixels-per-inch - 400 is the output width
- 600 is the output height
- "output.png" is the output file name
-Tres
Liam,
slave liam
-- Liam Quin - web slave for https://www.fromoldbooks.org/ with fabulous vintage art and fascinating texts to read. Click here to have the slave beaten.
2020-04-23 17:39:23 UTC (almost 5 years ago)
Are there any known caveats to running these command on Windows?
I'm testing the above with CMD and no matter how I run it, it pops up a dialog asking me what resolution to import the file at, I can't get it to run non-interactively.
- I've tried escaping the asterisks - I've tried gimp-2.10.exe
- I've tried gimp-console-2.10.exe - I've tried swapping single quotes and double-quotes
It works on macOS Gimp 2.10.14 but does not work on Windows using Gimp 2.10.18.
When I try to run the first portion interactively, I receive the following errors:
- Opening *'C:\Users\owner\Desktop\((image'* failed: Error opening file C:\Users\owner\Desktop\((image: No such file or directory - Opening *'C:\Users\owner\Desktop\(car'* failed: Error opening file C:\Users\owner\Desktop\(car: No such file or directory - Opening *'C:\Users\owner\Desktop\(file-svg-load'* failed: Error opening file C:\Users\owner\Desktop\(file-svg-load: No such file or directory
I've tried using PowerShell and receive very similar results. What am I doing wrong?
-Tres
On Thu, Apr 23, 2020 at 11:51 AM Tres Finocchiaro < tres.finocchiaro@gmail.com> wrote:
Where:
-Tres
Liam,
slave liam
2020-04-23 17:51:03 UTC (almost 5 years ago)
Ok, I got it. Had to remove all single quotes and use backslash instead of uptick to escape the double-quotes.
Here's a working Windows example: https://gist.github.com/tresf/1bd76fc8cd4a4def215c68cab990dfb1
Thanks again for the help.
-Tres
Where:
-Tres
Liam,
slave liam
2020-04-23 18:00:35 UTC (almost 5 years ago)
Link to originating question: https://superuser.com/a/1545028/443147
On Thu, Apr 23, 2020 at 1:39 PM Tres Finocchiaro < tres.finocchiaro@gmail.com> wrote:
-Tres
Where:
-Tres
Liam,
slave liam
