Background Layer Color
10 of 10 messages available
Background Layer Color Maestro 15 Apr 23:26
  Background Layer Color rich404 16 Apr 08:05
   opening and creating WMF files with GIMP 2.10.18 Jean-Yves VAUTRIN 16 Apr 12:47
    opening and creating WMF files with GIMP 2.10.18 Alexandre Prokoudine via gimp-user-list 16 Apr 14:22
     opening and creating WMF files with GIMP 2.10.18 Alexandre Prokoudine via gimp-user-list 16 Apr 14:29
     opening and creating WMF files with GIMP 2.10.18 Jernej Simončič 16 Apr 14:33
   Background Layer Color Maestro 16 Apr 13:29
   Background Layer Color Maestro 16 Apr 13:42
    Background Layer Color rich404 16 Apr 17:14
     Background Layer Color Maestro 16 Apr 22:59
2020-04-15 23:26:05 UTC (about 5 years ago)
I just created a graphic, and made the background transparent...or so I thought. But, when I export this as a .jpg file, the background is some kind of maroon or brick color. I cannot figure out how I did that, and it's something I certainly don't want. How do I fix it? Many thanks!
Attachments: * https://www.gimpusers.com/system/attachments/1399/original/EEC_Music_Ministry_Making_the_Pitch.xcf * https://www.gimpusers.com/system/attachments/1400/original/EEC_Music_Ministry_Making_the_Pitch.jpg
Maestro (via www.gimpusers.com/forums)
2020-04-16 08:05:52 UTC (about 5 years ago)
The jpeg format does not support transparency. Export your image as a png.
Why the maroon colour? When you export to a jpeg any transparency is replaced by the Gimp current BackGround value (BG) Usually the user will set that as white, but can be some other colour.
see the screenshot:
How to fix it. Start again. Always Save as a Gimp xcf until a final export to png/jpg/tiff etc.
Attachments: * https://www.gimpusers.com/system/attachments/1401/original/background.jpg
Jean-Yves VAUTRIN
2020-04-16 12:47:02 UTC (about 5 years ago)
I have erased  all looking like GIMP on my hard disk, even C:\Users\PC-JY\AppData before installing 2.10.18
When I try to open a wmf file, I have as response the file attached.
I can't also exporting a picture as wmf file.
If someone has a response,
Thank you,
JY
2020-04-16 13:29:12 UTC (about 5 years ago)
Thank you so much for your response and help. Perfect answers! Much appreciated.
2020-04-16 13:42:17 UTC (about 5 years ago)
One more thing, if I may...
How do I change that background colour from maroon to white. The bucket tool isn't doing it.
2020-04-16 14:22:58 UTC (about 5 years ago)
It's not supported. WMF is primarily a vector graphics file format. GIMP neither imports nor exports it.
Alex
2020-04-16 14:29:43 UTC (about 5 years ago)
Ah, I stand corrected. Apparently, I never bothered to build it with libwmf. Sorry about the confusion!
Alex
Jernej Simončič
2020-04-16 14:33:50 UTC (about 5 years ago)
On Thursday, April 16, 2020, 16:22:58, Alexandre Prokoudine via gimp-user-list wrote:
WFM import should be supported, but I just tested this on Windows, and the plugin crashes on the files I have.
< Jernej Simončič ><><><><>< https://eternallybored.org/ >
A military disaster may produce a better postwar situation than victory.
       -- White Flag Principle
2020-04-16 17:14:33 UTC (about 5 years ago)
You do not need to fill anything. You have done everything right.
Your Gimp xcf file keeps everything separate in layers.
Just export that as a png file for a flattened image with transparency.
If you want a jpeg file with a white background, set the Gimp BG colour in the tools dock to white.
Then export the image as a jpeg.
This might / might-not help. A minute and a half video demo of the above https://youtu.be/bGaOxdsAbHI
2020-04-16 22:59:05 UTC (about 5 years ago)
Again, my thanks to you, rich404. Got everything fixed, and I also learned something new. Much appreciated!
