High bit depth PSD export
High bit depth PSD export Grunthal, Aaron via gimp-user-list 07 Apr 15:14
2020-04-07 15:14:20 UTC (about 5 years ago)
I am trying to make a 32bit linear float GIMP image stack available to photoshop users, but when creating a PSD either via script-fu file-psd-save or the export menu the exported PSD always ends up as 8bpc. This is unexpected since the release notes for 2.10 state that opening and exporting PSDs supports high bit depth[0] and I am using 2.10.18.
On the other hand there is this source code comment[1] indicating that exporting only supports 8bpc.
Are the release notes mistaken or am I missing some precondition for high bit depth exports?
[0] https://www.gimp.org/release-notes/gimp-2.10.html#gegl-port-high-bit-depth-support-multi-threading-and-more [1] https://gitlab.gnome.org/GNOME/gimp/-/blob/3f66f2df39e2567d8b22f1532bda1153dd99f68a/plug-ins/file-psd/psd-save.c#L538
This message is for the designated recipient only and may contain privileged, proprietary, or otherwise private information. If you have received it in error, please notify the sender immediately and delete the original. Any other use of the email by you is prohibited.
