Tool Box Top Line
Tool Box Top Line Timhockswender 07 Dec 00:46
  Tool Box Top Line rich404 07 Dec 11:30
2019-12-07 00:46:32 UTC (about 5 years ago)
Tool Box Top Line
Just after using the selector to crop, the entire top line of the toolbox(the line with the various selectors) disappeared!
I reset everything to default but no luck. Any thoughts?
Timhockswender (via www.gimpusers.com/forums)
2019-12-07 11:30:04 UTC (about 5 years ago)
Tool Box Top Line
You should always state Gimp version and Operating system (OSX is often peculiar)
However, best guess you hit the tab key for 'hide-docks' see the Gimp Windows menu for the Hide Docks toggle.
otherwise you can go into Edit -> Preferences and reset window to default https://i.imgur.com/aGM8ooc.jpg
