LOCK alpha
7 of 8 messages available
LOCK alpha Lordgil 29 Aug 19:01
  LOCK alpha Ofnuts 29 Aug 21:42
   LOCK alpha ̵tImposterMO̵ t̵ via gimp-user-list 30 Aug 00:06
    LOCK alpha Ofnuts 30 Aug 00:17
     CAHJUnC=tT5CVbXEX4c+LuoRF5Z... 30 Aug 14:35
      LOCK alpha Ofnuts 30 Aug 14:35
       LOCK alpha ̵tImposterMO̵ t̵ via gimp-user-list 30 Aug 19:03
        LOCK alpha Ofnuts 30 Aug 21:01
2019-08-29 19:01:35 UTC (over 5 years ago)
LOCK alpha
I'am new
I am on windows 10 Gimp 2.10
I often very often use the eraser tool, and each time thpixel and alpha channel are locked
I don,t need this to do
I tried Edit / Preference toolbox reset to default save and this don't work
on a next restart I did it several times and nothing Is there another trick to avoid this lock alltime Thank You
Lordgil (via www.gimpusers.com/forums)
2019-08-29 21:42:24 UTC (over 5 years ago)
LOCK alpha
On 8/29/19 9:01 PM, Lordgil wrote:
I'am new
Locks (pixel, move and alpha) are a property of the image/layer. If you save an image with these locks set, next time you load the image the same layers will be locked. To reset them permanently, remove them and save the image.
2019-08-30 00:06:06 UTC (over 5 years ago)
LOCK alpha
Is there a hotkey for this layer lock? I only see a visibility icon checkbox and sometimes I have a problem selecting overlapping layers. Is there a method to "tab" thru layers at selected point?
Also any one know how to batch all colors using select by color. Ie FOR command with all HEX color codes to create a PAINT BY NUMBER plugin or perhaps lighting effect shader. Later can I improve with threshold tolerance to group colors or use a pallete and cycle thru colors for selected areas. This would be great in video games as alternative to pixel sprite mapping. IE every bitmap pixel color is a Sprite_gamestate withX overlapping images represented as unique colors.
I'am new
are locked
don't work
2019-08-30 00:17:47 UTC (over 5 years ago)
LOCK alpha
No but you can define one.
PgUp/PgDn?
In a color-indexed image, this is just editing the colormap. You are restricted to 256 colors, but I don't think you would want to handle 24M color that way.
2019-08-30 14:35:32 UTC (over 5 years ago)
LOCK alpha
On 8/30/19 2:28 AM, ̵tImposterMO̵ t̵ wrote:
- In a color-indexed image, this is just editing the colormap. You are restricted to 256 colors, but I don't think you would want to handle 24M color that way.
Yes if I use a color pallete do you know any references to Python or Perl? for plugins to manipulate color selections like replace color with white and text for color pallete index number. IE a paint by number script
No, but is is needed?
You can edit the color map (Windows>Dockable dialogs>Color map), and in the colormap dialog, you can select a color by number and change it to change the corresponding pixels. Looks a lot like your "paint by number"...
2019-08-30 19:03:55 UTC (over 5 years ago)
LOCK alpha
Is there a way to view the object/property or debug names of GUI objects in GIMP for use with scripting or customization(s)? I would like to know how to edit elements in the colormap dialog procedure-ally to make scripts like Art To Paint by Number; To Stain'd Glass; To lighting effect for shader This is more difficult because its not select by number but by pixel color glob contiguous group.
ofnuts* wrote: You can edit the color map (Windows>Dockable dialogs>Color map), and in the colormap dialog, you can select a color by number and change it to change the corresponding pixels. Looks a lot like your "paint by number"...
2019-08-30 21:01:29 UTC (over 5 years ago)
LOCK alpha
See the gimp_image_{get|set}_colormap() functions in the API (Scheme or Python).
Scripts and plugins cannot interact with the Gimp UI directly.
