Need some help and advice about Scripts
Need some help and advice about Scripts krystalmk 17 Aug 18:30
  Need some help and advice about Scripts rich404 17 Aug 19:39
   Need some help and advice about Scripts krystalmk 17 Aug 22:19
2019-08-17 18:30:22 UTC (over 5 years ago)
Hi There! I am still technically a Gimp "beginner" as I don't use it that much, only for some very important filters and a few things like that. But lately I have been determined to learn a lot more about how to use Brushes. I understand how to install them and see them with the Airbrush or Paintbrush. But I have had trouble changing and keeping the foreground color which, if you are for example adding cloud brushes to a photograph, you would change to white...but I can't figure out how to easily switch colors. I considered trying to get a Script and found something that might work. But now I am confused about how to implement scripts. It might be that I installed in the wrong location. I have noticed something strange, and rather than try to explain it in words I made a couple of images to show you. Why is one of my script folders blank??? Advice and guidance on this would be very much appreciated --- Thank You
Attachments: * https://www.gimpusers.com/system/attachments/1240/original/Image1gimp.jpg * https://www.gimpusers.com/system/attachments/1241/original/Image2gimp.jpg
krystalmk (via www.gimpusers.com/forums)
2019-08-17 19:39:31 UTC (over 5 years ago)
There is no real mystery about the two folders. Your first screenshot are the scripts that come with a Gimp installation and the second is your Gimp profile scripts folder. The Gimp profile is the place to add any scripts that are for your use. Not added any? Then it is empty. If you look in Edit -> Preferences -> Folders -> Scripts you will see those two paths. The same applies to the other resources, for example brushes go in C:\Users\Krystal\Appdata\Roaming\GIMP\2.10\brushes
....but I can't figure out how to easily switch colors...
A better question might be why do you have difficulty switching colours. If you have white as the BG colour and you want it as FG for painting then the 'X' key swaps FG/BG.
2019-08-17 22:19:18 UTC (over 5 years ago)
swaps FG/BG.
******* Okay! I didn’t know that, but your advice will be a big help, Thanks very much!
