Help
Help Janet Karabin via gimp-user-list 28 Jul 23:16
  Help Agetaing47 30 Apr 09:53
  Help programmer_ceds 30 Apr 13:29
2019-07-28 23:16:07 UTC (over 5 years ago)
Help
I just downloaded the Windows Version of GIMP and when I came to the section of tutorial indicating:
$B!H(BAlso notice I have shown a different option under Quality $B"*(B Interpolation. The default value for this is Cubic, but to retain the best quality it would better to use Sinc (Lanczos3).$B!I(B
My only options were:
None
Linear
Cubic
NoHalo
LoHalo
I want to enlarge smaller photos while maintaining pixel integrity.
How do I get the Sinc option as referenced in the tutorial? Or which option should I choose for similar results.
Thank you for your time, I appreciate it.
2020-04-30 09:53:41 UTC (almost 5 years ago)
Help
As I understand you are facing error to install latest version window. Also, you can check https://assignmentjunkie.co.uk/essay-writer info to complete your task easily. I also install many windows in any system and also using latest window 10. Now every student can get latest information to install window in their system.
2020-04-30 13:29:29 UTC (almost 5 years ago)
Help
Sinc disappeared with the advent of GIMP V2.10. I believe that the best interpolation to use may depend on the contents of the image. Try experimenting with different interpolations. With V2.8 there were some issues with the Sinc interpolation and I used Cubic then.
None
Linear
Cubic
NoHalo
LoHalo
programmer_ceds (via www.gimpusers.com/forums)
