Clone Tool not working
8 of 8 messages available
Clone Tool not working louisbosqui 28 Jun 10:33
  Clone Tool not working rich404 28 Jun 11:21
   Clone Tool not working louisbosqui 28 Jun 12:12
    Clone Tool not working robin48gx 11 Aug 14:35
    Clone Tool not working robin48gx 11 Aug 14:37
     Clone Tool not working robin48gx 11 Aug 14:44
     Clone Tool not working efsandino 29 Sep 22:01
  Clone Tool not working pvanderv 15 Aug 19:28
2019-06-28 10:33:31 UTC (almost 6 years ago)
Hello!
I had the 2.10.10 version of Gimp on my computer and was editing many pictures everyday, especially using the clone tool. All of a sudden, out of nowhere, the clone tool stopped working. I set the "source spot" using ctrl+left click and then wanted to start painting my selection from my source but when I clicked and dragged across my selection, nothing happened. It didn't change the image.
I updated to version 2.10.12 (latest version) but i still have the same problem.
Any help is appreciated, thanks!
louisbosqui
2019-06-28 11:21:55 UTC (almost 6 years ago)
Hello!
louisbosqui
Guessing a Windows user. Updating Gimp is not a bad idea however please note that re-installing Gimp does not remove/change your Gimp profile where the tool settings are kept.
C:\Users\"yourname"\AppData\Roaming\GIMP\2.10\
First thing to check is the Alignment - right down at the bottom of the menu (1) and often overlooked. If that is in 'Registered' mode then for a single layer you are cloning on top of the source and nothing happens.
While there try a reset to default values (2), might be a fix.
Still not working? Rename that Gimp profile as a backup. Start Gimp up and it makes a new default profile. Check it works ok. Copy any resources brushes/scripts..etc over from the backup.
2019-06-28 12:12:26 UTC (almost 6 years ago)
Resetting the tool worked. Many thanks!!!
2020-08-11 14:35:04 UTC (over 4 years ago)
This is awful and wastes peoples time. I used to like GIMP but am finding the new versions are often, just nOT DOING ANYTHING and NOT TELLING you why.
IS it abandonware ?
2020-08-11 14:37:34 UTC (over 4 years ago)
I cannot even find the menu item "alignment"
2020-08-11 14:44:20 UTC (over 4 years ago)
OK found it now BUT the clone tool still refuses to clone. TBH I have had many fights and wasted half hours with GIMP after using it quite happily for decades.
The export when you loaded a JPG to start with was probably the begining of the end.
I am now finding GIMP unusable.
2021-08-15 19:28:41 UTC (over 3 years ago)
I had this same problem. Finally figured out I had the wrong brush selected. Open the brush selection box. Make sure you have selected the one that looks like a circle with fuzzy edges.
2021-09-29 22:01:10 UTC (over 3 years ago)
I had to solve from this way. I exported what I needed to clone in a new image, then open the new image and clone tool worked there, i worked on that image then copied back my changed layer.
Very very strange.
