Lasso tool not selecting
Lasso tool not selecting strangemountain 28 May 04:21
  Lasso tool not selecting rich404 28 May 09:59
   Lasso tool not selecting strangemountain 28 May 11:13
2019-05-28 04:21:56 UTC (almost 6 years ago)
Hi, I have issues with the lasso / free selection tool. It just doesn't add multiple selections. I have updated to gimp 2.10.10, I have reset the tool. I make a selection and then press shift to add another selection on the same layer, but it doesn't work. The + doesn't appear. I try it with clicking on the add modus in the tools menu, but again, no +, no selection. The first selection is still there, but wherever I click, nothing happens. It works fine with the rectancle selection tool, also with ellipse. Also the same is with substract from selection. Anyone an idea? Is this a bug?
2019-05-28 09:59:20 UTC (almost 6 years ago)
It is a slight change from Gimp 2.8. In Gimp 2.10 you can adjust the free-selection before committing.
Hit the enter key to fix the initial selection. Shift - then adds. Hit the enter key to fix.
example https://imgur.com/a/eMuqM9f
2019-05-28 11:13:10 UTC (almost 6 years ago)
That's it, I didn't know. Thank you very much!
