Script-Fu local procedure question
Script-Fu local procedure question Helmut Jarausch via gimp-user-list 16 Apr 10:04
  Script-Fu local procedure question Ofnuts 16 Apr 20:58
2019-04-16 10:04:01 UTC (about 6 years ago)
I have an old script-fu script which contains
(if (not convolution-preset-type-is-basic) (script-fu-register "script-fu-convolution-presets-blur-symmetric" "Symmetric Blur..."
(string-append CONV-PRESET-DESCRIPTION "(Symmetric Blur)") "Iccii "
CONV-PRESET-COPYRIGHT
CONV-PRESET-DATE
CONV-PRESET-IMAGE-TYPE
SF-IMAGE "Image" 0 SF-DRAWABLE "Drawable" 0 SF-OPTION "Matrix Type" CONV-PRESET-TYPE-LIST SF-ADJUSTMENT "Amount" '(3 1 128 1 1 0 0) SF-ADJUSTMENT "Center Value" '(1 1 128 1 1 0 0) SF-TOGGLE "Calculate Divisor" TRUE SF-TOGGLE "Alpha-weighting" TRUE SF-OPTION "Edge" CONV-PRESET-EDGE-LIST SF-TOGGLE "Gray Channel" FALSE SF-TOGGLE "Red Channel" TRUE SF-TOGGLE "Green Channel" TRUE SF-TOGGLE "Blue Channel" TRUE SF-TOGGLE "Alpha Channel" FALSE) (script-fu-menu-register "script-fu-convolution-presets-blur-symmetric" "/FX-Foundry/Convolution Matrix Presets")
i.e. the script-fu-register function call is within an 'if' clause. Now I get the error message
script-fu-Warning: Procedure script-fu-convolution-presets-blur-symmetric in script-fu-menu-register does not exist
What can I do about this?
Many thanks for a hint, Helmut
2019-04-16 20:58:02 UTC (about 6 years ago)
The registration being in an IF clause isn't a problem per se.
The FX-foundry stuff dates back to Gimp 2.6 (or 2.4?) and seems to have been unmaintained since. It could be time to retire it, or steal whatever code you need for your own scripts.
