Gimp freezing on path tabs
Gimp freezing on path tabs bshorey 13 Apr 14:03
  Gimp freezing on path tabs rich404 13 Apr 16:30
2019-04-13 14:03:40 UTC (about 6 years ago)
I'm converting some text to paths. Has no problem performing the function (although when I initially click on the paths tab, I have to wait several minutes for it to stop spinning the color wheel and show the tab with the new layer), but when I try to make the new layer path visible, I get the spinning wheel of death and the application stops responding. Please help.
2019-04-13 16:30:54 UTC (about 6 years ago)
Guessing your computer has run out of resources.
That font Amatic Bold is described as "simple but effective hand drawn".
Looks to have about 8 times as many nodes as a regular font-to-path. see screenshot.
From your screenshot the text looks fairly dense. You could try creating a line at a time then merge the individual paths.
A better solution might be not-gimp. Use a vector application such as Inkscape.
